"Retro Dissipator" - my Colt M16 Model 605 clone...
Discussion in 'Hunting & Fishing' started by Brian in Oregon, Oct 2, 2008.
  1. Brian in Oregon
    Brian in Oregon
    3,040
    2
    Dec 17, 2005
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    I remember as a kid seeing photos in various gun books, like Small Arms of the World, photos of the 15" M16 carbine, Colt Model 605, I always wanted one. Finally decided to build one.
    The original 605 was nothing more than the M16 with the barrel cut back to 15", so that the flash hider was almost up against the front sight tower. This made for a nice short, handy carbine. Alas, the short distance between the gas port and the muzzle led to unreliable operation. The 605 predated the XM177E2 that everyone knows as the M16 or AR15 "Shorty".
    The solution was to use a Bushmaster 16" Dissipator barrel. I installed a Dissipator heavy barrel (which is also available in a lighter M4 pattern) onto an old Colt "Slickside" upper. Pretty straightforward. The only modification needed was to section some of the inner heat shields in the forends away to clear the Dissipator gas block, as well as a bit of filing on the ends of a reinforcing rib on each side. Then screw on the later open three prong flash hider. The buttstock is an old A1 pattern with no trapdoor. I have not milled off the bayonet lug yet.
    The overall weight is close to skinny barrel A1 rifle, even though the barrel is much thicker (HBAR dimensions). The balance points for the two are very close. The result is a very stable carbine with a solid feel, but it doesn't weigh much more than the A1. I'm hoping this will make a good iron sighted tactical rifle for putting lots of lead downrange in tactical matches.
    EDIT: The actual weight is 10 oz more than the A1.
    If you're not familiar with the Bushmaster Dissipator, the front sight tower has no gas tube. A read gas block is in the same position of a 16" carbine. This ensures reliable gas operation.
    I have not shot it yet. Alas, I ordered the wrong offset pin to mate the large pin Colt upper to the small pin Bushmaster lower. Hopefully I'll have the proper pin shortly and can test fire it.
    Colt Model 605
  2. Landpimp
    Landpimp GOLD Star
    14,181
    523
    Mar 14, 2003
    PNW
    nice work, I dig it :)
  3. Liam
    Liam
    4,555
    4
    Feb 10, 2005
    in the nappy dugout
    very nice....
  4. nat
    nat
    1,973
    25
    Sep 20, 2005
    Los Gatos, California
    Yep, it looks pretty cool.
    :cheers:
  5. Brian in Oregon
    Brian in Oregon
    3,040
    2
    Dec 17, 2005
    Realized I never updated this thread with a range report.
    The gun is rock solid in your hands when shooting. And it is quite accurate. Have it sighted in at 250 yards, and am having no problem hitting vegetable and soup cans at that distance. It's the most accurate iron sighted AR I have.
    Worked out so well I'm tempted to make another with the lightweight Dissipator barrel.
  6. Retro Jim
    Retro Jim
    1
    May 20, 2013
    Her is my shortened M16A1 Upper.
    I shortened the 20" Barrel to !6"
    Threaded and installed A2 Flash Suppressor.
    The trick to making it work was to open the Gas port in the barrel & Front sight to .080
    [​IMG]
  7. EWTexas
    EWTexas
    290
    4
    Oct 1, 2010
    Lubbock Tx
    Nice looking, maybe I should have done that to my SP1 instead of the 16" M4 barrel I installed.
