Restoring Green Bean '82 FJ40
Discussion in '40- & 55-Series Tech' started by akingf5371, Apr 1, 2013.
  1. akingf5371
    akingf5371
    829
    64
    Sep 3, 2011
    Denver, CO
    Shane, I actually ordered 4 from real steel with the rest of my panels. I didn't know if I would need to replace all 4 but I was sure on 2 so I hedged my bet.
  2. akingf5371
    akingf5371
    829
    64
    Sep 3, 2011
    Denver, CO
    Fixing this rib with my patch panel. I thought they would be almost identical. I think they are dissimilar enough to warrant replacing the whole rib.
  3. akingf5371
    akingf5371
    829
    64
    Sep 3, 2011
    Denver, CO
    Replaced the rib in full. I think it looks pretty good. I had to weld the bottom of this from the inside of the wheel well, but it still popped due to body filler. Got a new set of burrs that have some pretty small balls that I will be able to really grind the small parts flat.
    I think the rib looks pretty good. It might not be 100% perfect but without a ruler I don't think anyone would be able to tell.
    alabamatacomaguy likes this.
  4. Ken White
    Ken White
    768
    335
    May 8, 2014
    Cooktown, Queensland
    Adam looks like you are progressing well with the rebuild. I will be watching this thread closely as I too have no welding experience and have a BJ42 that needs a bit of work done on her.
  5. akingf5371
    akingf5371
    829
    64
    Sep 3, 2011
    Denver, CO
    Thanks Ken, I feel it goes slower then it should. Buy a welder and jump in! That's what I did for the most part. I honestly think the prepping of the panel is more difficult than the welding part. To make sure it's flush and even and ready to weld takes patience and practice.
  6. SteveH
    SteveH
    2,326
    211
    Jan 17, 2005
    Southern Colorado
    Man - that looks great. Jumping in is right - at some point, you fire up the welder realizing that you cannot make the situation worse. Once you've honed your skills on the hidden parts (holes under your feet), then you start welding visible panels.
  7. Jacket
    Jacket Moderator
    1,210
    85
    May 26, 2007
    Boulder, Colorado
    Good stuff - you just jumped right in. That's the same way I got going with mine - just bought a welder and started playing with it to replace my rear sill and rusted quarters. But somehow 3 years have now gone by and I haven't got back to it. :(
    How are your floorboards? That's next for me and for $150 the Real Steel floor pan looks like a good option.
  8. micdon
    micdon
    331
    35
    Nov 25, 2012
    Almere,The Netherlands
    If you don't have anything else available, even regular zinkspray will do
  9. akingf5371
    akingf5371
    829
    64
    Sep 3, 2011
    Denver, CO
    More work! Going to have to be a bondo expert to get everything nice and smooth
  10. akingf5371
    akingf5371
    829
    64
    Sep 3, 2011
    Denver, CO
    Replacing the front brace. Took much more time than I thought!
    Chungas Revenge likes this.
  11. akingf5371
    akingf5371
    829
    64
    Sep 3, 2011
    Denver, CO
    Final pictures from today!
  12. akingf5371
    akingf5371
    829
    64
    Sep 3, 2011
    Denver, CO
    Forgot about the top! I will be doing this different on the next 3. I just filled in the holes with the mig, that wasn't great as it was much thinner than I anticipated. I'm replacing it with fresh steel. I also filled in the holes for the roll bar, first by accident and then I went ahead did the rest of them. I'm still on the fence about replacing the capture nuts or just using normal nuts.
  13. akingf5371
    akingf5371
    829
    64
    Sep 3, 2011
    Denver, CO
    Today's work.
  14. coinoperated40
    coinoperated40 Miss the place
    812
    97
    Jan 6, 2011
    Salisbury, N.C.
    I like the work you're doing. Tried some welding today and would not post any pictures of it at all. I need a lot of practice.
    Keep it going.
  15. akingf5371
    akingf5371
    829
    64
    Sep 3, 2011
    Denver, CO
    Ha! I can't say I make the prettiest welds. I feel like I'm improving. Prep is the key I've noticed. One bite at a time!
  16. coinoperated40
    812
    97
    Jan 6, 2011
    Salisbury, N.C.
    The welding just got some better. Ran out of wire and figured the wire that was on the welder was a sample spool that came with the machine. The welder is over 15 years old.
    I have cut and reversed a tail gate latch and need to weld it, so I am about ready to try.
    Weld on..
  17. akingf5371
    akingf5371
    829
    64
    Sep 3, 2011
    Denver, CO
    Wheel well getting close to done
  18. Ken White
    Ken White
    768
    335
    May 8, 2014
    Looks like you are getting there mate. I have just started to teach myself how to MIG weld and I like Coinoperated need a lot of practice. I notice that you seem to just run spot welds and no runs when you patch your part. Is there any reason for this. Keep up the posts and good work.
  19. coinoperated40
    812
    97
    Jan 6, 2011
    Salisbury, N.C.
    I think running spot welds on the thin metal helps from warp. If not someone will point me in the right direction..
    Getting back to practice as soon as the family leaves. Did this to get the grill off the wheels. It didn't fall when I put the granite top on, so that was a good sign. image.jpg
  20. subzali
    subzali
    3,058
    130
    Jan 31, 2005
    Denver CO
    Adam, capture (ie weld) those roll bar nuts in. Just trust me
    ...via IH8MUD app
