Removing rear wheel cone washer
Discussion in '80-Series Tech' started by medtro, Jun 23, 2003.
  1. medtro
    medtro
    5,626
    455
    May 31, 2003
    When removing cone washers from the rear wheel of a 80, the FSM says hit the axle center with brass punch. Any ideas why not hit the studs like in the front?
    medtro
  2. cruiserdan
    cruiserdan SupportingVendor Emeritus Supporting Vendor Moderator
    20,603
    2,981
    Mar 27, 2003
    Surrounded by Cruisers from all over the world
    I smack (smart taps) the edge of the flange with a 16 oz machinists hammer.  :G  The reason they want you to smack the studs on the front is because there isn't a nice flange in the center to pound on. Hitting it in the center spreads the force out. Remember, hit it, don't HIT IT............
     BTW I did my rears yesterday. Don't ignore them, you may not like what you see if you do.................. :ugh:
  3. Beowulf
    Beowulf
    12,534
    30
    Mar 27, 2003
    Somewhere in the foothills...
    >> ... you may not like what you see if you do <<
    Or what you *don't* see... wheel bearing grease.
    Medtro,
    I don't hit the studs (front or rear.)  A brass hammer works well when struck against the side of the flange. Loosen the nuts but leave about 2 threads so the cone washers don't fly all over the garage.  "You could loose an eye doing that."  :G
    -B-
  4. Chris_Geiger
    Chris_Geiger
    305
    Mar 28, 2003
    I just pulled mine out a couple weeks ago and they popped right out after a couple hits on the out side of the flange.
  5. medtro
    medtro
    5,626
    455
    May 31, 2003
    I left the nuts on when I hit the studs so that I will have my both eyes to do the other wheels.
    I opened both rear wheels yesterday, and I like everything I saw in there. Ok, I repacked them a few weeks ago, and they still look good.
