Removing Nails from Cinder Block
Discussion in 'Workshop and Home Improvement' started by El Cazador, Jul 11, 2009.
  1. El Cazador
    El Cazador
    595
    1
    Sep 24, 2005
    SoCal
    The owner said I could clear out some of the old work benches & shelves so I could have more room. The 2x4's were attached with a nail gun. Big frickin' nails too. What's the best way to get the 2x4 off w/o destroying the cinder block.
  2. KLF
    KLF Frame waxer SILVER Star
    6,283
    489
    Apr 5, 2003
    Southern NH
    Cat's Paw and a big honkin' pry bar.
    You may end up pulling the heads off the nails. Just get the boards off, then snap the nails off flush with the blocks.
  3. D'Animal
    D'Animal Rescuer of Beagles & Landcruisers Moderator
    21,111
    Media:
    180
    259
    Mar 31, 2006
    Central California
    I would start with a catspaw or prybar to see if the nail will come out. If not, I would use a saws all and cut the board and the plate from around the nail head. I would then use the catspaw or prybar to see if the nail will come out again. If not, cut the head off the nail and drive it all the way in.
  4. nat88toy
    nat88toy
    1,308
    Mar 6, 2006
    C4 is your friend :hillbilly: agree with both statements above thats the way i would do it
  5. jellyroll
    jellyroll
    55
    Apr 22, 2007
    just short of the 49th parallel
    That nail and plate looks as if its been shot in with some sort of powder actuated fastening gun, ( Ramset or something like it). If you have to use anything larger than a flat pry bar behind the lumber, and have to use substantial force, the odds are fairly high that your going to at least pop a small part of the block face off. If thats fine, find the biggest damn pry bar you can find.
    To get the cleanest look, Sawsall the nail behind the board, or split the board around the nail and then snap them off as noted earlier. Remember if those little bastards were put in properly, they're meant to stay in there under stressfull conditions, and their going to fight to come out.
  6. fsusteve
    fsusteve
    3,802
    Media:
    18
    50
    Aug 2, 2003
    Naples/Big Pine Key, Fl
    sawzall, otherwise you'll get familiar with stucco patch.
  7. splitshot
    splitshot Head cook, Bottle washer, and Peace keeper. SILVER Star
    6,478
    Media:
    11
    590
    Nov 17, 2006
    Rodent Central, Az
    4 1/2, or a die grinder with a cut off blade. Take the head first, and after the lumber is pulled, cut the shank flush with the wall.
  8. Cube Dweller
    Cube Dweller Moderator
    1,183
    11
    May 22, 2004
    22 Acacia Avenue
    x2...
  9. bkfj40
    bkfj40 SILVER Star
    2,790
    Media:
    20
    203
    Apr 5, 2002
    shenandoah valley, va
    it's only gaining you 1 1/2" - incorporate it into the design of what you want to do.
    work smarter, not harder.
    bk
  10. wob
    wob
    2,813
    674
    Feb 28, 2003
    SC
    Grind the nail heads off, remove the board, then grind the nails down.
