rebuilt alternator
Discussion in '80-Series Tech' started by thorvald, Sep 8, 2003.
  1. thorvald
    thorvald .......
    1,569
    Media:
    19
    23
    Aug 18, 2002
    on the ice, wyoming
    going to be taking my alternator off as its throwing out 16-18 volts ( not good is it?) and have it bench tested. does napa have good rebuilt ones?
    was looking at mean green but there isnt one listed for 91-92 ???
    could just do the brush kit but pretty sure im hearing bearing noise from there as well.
    any rebuilt ones to seek out or avoid? its a reman on there already, least thats what the sticker says
  2. Landpimp
    Landpimp GOLD Star
    14,687
    869
    Mar 14, 2003
    PNW
    personaly I would get a new reman alt from Toyota, thats what I reppaced mine with at 110k and at 220k, not any high amp units made for the 3fe. Personaly I would not get a parts store re build or re man.
    John H
  3. cary
    cary
    3,109
    21
    May 7, 2003
    I would only use two alternators on the 80, either the factory part, or a Bosch rebuilt (essentially oem). Reason is many rebuilts are only new brushes, no new bearings or anything else. You replace the alternator and 6 months later you need to do it again because the bearing goes south.
    That said, you may be able to just put a new voltage regulator in the one you have.
    Cary
