rebuild
Discussion in '80-Series Tech' started by cruiserman, Sep 17, 2003.
  1. cruiserman
    cruiserman
    1,861
    Mar 27, 2003
    Finally got the head placed on the block tonight. I'm hoping to try to put the motor back in the rig this weekend.
  2. landtank
    landtank SILVER Star
    18,425
    601
    Mar 27, 2003
    Groveland MA
    Was wondering what was happening on your truck.
    Seems like these issues arrise and then just disappear. Like Junks tranny problem and that won't start problem a week ago. Thanks for the followup
  3. cruiserdan
    cruiserdan SupportingVendor Emeritus Supporting Vendor Moderator
    20,580
    2,898
    Mar 27, 2003
    Surrounded by Cruisers from all over the world
    It's very easy to see the bib that the PHH fits on.
    I like it, the head is on the block and the block is on blocks ::)
    CM, dont forget to paint the block to prevent rust from forming on that nice clean surface........... ;)
    D-
  4. Desertmaster
    Desertmaster
    250
    Mar 28, 2003
    Looks good, hope you have a trouble free assembly.
    Al
  5. cruiserman
    cruiserman
    1,861
    Mar 27, 2003
    I thought about painting it, but wasn't sure what to use. Standard rustoleum, or something for high heat applications?
    I still need to pick up an engine stand to get the oil pan, etc. in place. The heater hose is easy to get to with the intake removed. A full motor extraction is not necessary :).
  6. Beowulf
    Beowulf
    12,534
    30
    Mar 27, 2003
    Somewhere in the foothills...
    Eric,
    I have read that there is a mysterious engine bushing (?) with an unobtainable part number that somehow gets destroyed (?) during an engine rebuild that involves boiling the block.
    Did you have that issue?
    -B-
  7. cruiserdan
    20,580
    2,898
    Mar 27, 2003
    Go to NAPA or the like and get gloss black "engine" paint and you'll be good to go. Don't get something like Plasti-kote Hi-temp paint as it has to be cured.
  8. Junk
    Junk
    6,185
    23
    Dec 13, 2002
    buggerville nj
    maybe you can pimp your engine too. :flipoff2: :wizz:
  9. TLCObsession
    TLCObsession
    149
    Apr 23, 2003
    Bellingham, WA (Lake Samish)
    How about a high heat in a light grey? Not stock, but a lot easier to see things - of course you will have NO leaks once it is all back together.
    Jim
    [quote author=cruiserman link=board=2;threadid=5390;start=msg42550#msg42550 date=1063902539]
    [/quote]
  10. TLCObsession
    TLCObsession
    149
    Apr 23, 2003
    Chix with bricks for blocks on blox! :D
    CDan - how about marking that picture and pointing out the bib?
    Jim
    [quote author=cruiserdan link=board=2;threadid=5390;start=msg42486#msg42486 date=1063892073]
    D-
    [/quote]
  11. cruiserman
    cruiserman
    1,861
    Mar 27, 2003
    [quote author=Beowulf link=board=2;threadid=5390;start=msg42553#msg42553 date=1063902911]
    Eric,
    -B-
    [/quote]
    Almost. I called the shop about it, and they were able to make a tool to remove/install the bushing. It's definitely an issue. Thanks to Robbie for bringing it up. It's the timing gear bushing.
  12. Beowulf
    Beowulf
    12,534
    30
    Mar 27, 2003
    I have to say that the 1FZ-FE owners are the luckiest people in the world to own these drop-dead gorgeous engines. That motor is a beautiful work of engineering and art.
    Woody. :D
    -B-
  13. cruiserman
    cruiserman
    1,861
    Mar 27, 2003
    I reluctantly checked the valve clearances tonight after swapping shims and installing new ones. One is at the tight limit on exhaust, but the rest have some margin.
    Dan, I wonder if replacing the timing chain tensioner would reduce or eliminate the startup rattle.
  14. Riley
    Riley
    1,613
    10
    Jun 20, 2003
    Fort Langley, BC
    Yes that's one beauty of a motor. Do tell - what caused you to redo the head?
    head gasket fail?
    In the end how much do this cost you to rebuild head ect...?
    R
  15. cruiserman
    cruiserman
    1,861
    Mar 27, 2003
    I didn't re-do the head. Machine shop rebuilt the bottom end and did a valve job on the head. #5 piston got too hot. Head gasket was in good shape.
    Cost is around US$2100 for parts & labor, not including new rad and fuel pump.
  16. sleeoffroad
    sleeoffroad Supporting Vendor
    6,056
    531
    Mar 27, 2003
    Eric, I assume you are installed a new slipper, guide, tensioner and timing chain? Also, did you do a new oil pump? These parts are not that expensive and it is pretty easy to do them now.
  17. sleeoffroad
    6,056
    531
    Mar 27, 2003
    Also a good time to rebuild the power steering pump and change all the low pressure hoses. Yours is a 93, age gets those things and they will eventually fail.
  18. cruiserman
    cruiserman
    1,861
    Mar 27, 2003
    [quote author=sleeoffroad link=board=2;threadid=5390;start=msg44084#msg44084 date=1064329848]
    [/quote]
    Christo, I replaced the timing parts but not the oil pump gears nor tensioner. You're right, the oil pump gears are inexpensive. The tensioner and gears appeared to be fine, but looking back I probably should have replaced them. Not too late, of course, but I really don't feel like pulling off the timing cover again, another new head gasket, etc. Hmm, SOR shows the tensioner at $22. Maybe I'll order one from Dan.
    I'm inclined to leave the PS pump alone as it was not leaking. I really like how it's driven directly off the crank rather than via belt. I will be replacing the fluid.
    I'm more concerned right now about figuring out why one of my valve clearances is at the low limit when it was in the middle of the range. Perhaps the head bolt torque procedure changed the shape of the head? At least it's on the exhaust cam, which is easier to pull than intake.
  19. sleeoffroad
    6,056
    531
    Mar 27, 2003
    [quote author=cruiserman link=board=2;threadid=5390;start=msg44093#msg44093 date=1064331230]
    Christo, I replaced the timing parts but not the oil pump gears nor tensioner. You're right, the oil pump gears are inexpensive. The tensioner and gears appeared to be fine, but looking back I probably should have replaced them. Not too late, of course, but I really don't feel like pulling off the timing cover again, another new head gasket, etc. Hmm, SOR shows the tensioner at $22. Maybe I'll order one from Dan.[/quote]
    The pump & tensioner can go in without removing the cover. You might need the gasket for the oil pump cover. Also, the screws are a bit of a pain to get off. Also, unless you have the main pan on already, you should be able to remove the timing cover.
    [/quote]
    Don't. The rebuilt kit is cheap. The pump blows it seal and then pumps the fluid into the motor. It is a bitch to get off when the motor is installed. Rebuild is pretty easy. Replace all the low pressure hoses while you are at it. I know of about 5 93's that developed a pin hole in the return lines. You have easy access to all those parts now. You can use regular ATF lines and hose clamps.
    [/quote]
    Did the shop do a valve job on the head? If so, did they remove some material from the valve stems? When we send a head to the shop, we have them set the valve clearances first. That way they can make sure to remove the correct amount from the valve stems. Then we re-set when the head is installed.
  20. Safado
    Safado
    1,156
    May 21, 2003
    Here....mostly.
    CDAN
    I too see many bibs....which one is the PHH bib from this perspective? ???
