RockJock82
Sometimes you have to kick a little A$$
I wanted to share some knowledge that I acquired from a friend regarding modifying your rear passanger side axle shaft. This will allow you to remove the twisted portion of the axle shaft if it breaks under load. My friend Kenny documented the process and dimensions where to modify the shaft. This can be done in your garage with an angle grinder or taken to a shop with a lathe. Lucky for him he has both .
