original brakes had an issue of needing 3-4 pumps on the pedal to get them to work. Decided (rather stupidly) to update the brake system to modern standards/safety for more reliable driving.
First step was the front axle. Updated to a '79-'85 mini truck. Added a Wilwood tandom cylinder too. Because the old system was a single circuit 9mm fittings, I replaced with really nice 3/16 Ni-Cop tubing and made my own ends.
The front calipers work great on their own. (With the rear output plugged) Because all four rear cylinders were beyond repair, I opted to go with '71+ newer cylinders and again make most of my own lines. After bleeding more than a gallon of fluid thru the system, the pedal still travels all the way to the floor.
M/C has the correct prop-valve setup.
Adjusted all four rear cylinders to just dragging and backed a few clicks.
Ordered cylinders from a land cruiser place but they sold me the Chinese knock offs.
I may just stick with running on the front brakes only as it still better than having to pump the brakes in hopes the rears connect. (I have a feeling that's what most do anyway) besides after throwing away 600 bucks at this, maybe it's time to move on to other projects that need to be done.
If anybody has done this on a 60's FJ with any success, I would be curious as to what worked.
Thanks for any ideas you may have.
