Rear body channel...
Discussion in '40- & 55-Series Tech' started by Brog, Jun 23, 2003.
  1. Brog
    Brog
    182
    Mar 31, 2003
    Chattavegas, TN
    Has anyone fabricated their own rear body channel rather than spending the $300 everyone wants for the prefabs?
    I plan on using 21/4" square tubing.
    Any suggestions?
    Thanks,
    Brog
  2. Paul_A
    Paul_A
    186
    Apr 1, 2003
    Rosendale, NY
    e it stretch betweeRe: Rear body channel...
    I did exactly that on a '70 that I owned way back when. I made it longer than the door openning so that it stretched from behind the quarter panel side to side, bolted it to the quarter panel on each side with a round headed bolt, ran the body mounts through it down to the rear frame member and made a sheet metal lip to merge the floor with the new cross piece. It was stronger than the original for a fraction of the cost and all that looked out of place were the two round headed bolts--painted nicely. Now if you can weld it in all the better!
  3. landcruiser
    landcruiser
    27
    Jan 24, 2003
    The previous owner of my 67 used a length of 2x4 rectangular tubing and welded it in place. can't be told from stock and the strength increase is impressive.
  4. Sparky_Mark
    Sparky_Mark
    191
    Mar 13, 2003
    Raleign / Durham, NC
    I saw a vehicle that used a standard tubing size - I think it was 3" x 5" x 1/8". The extra width makes it easy to tie into the existing floorpan. It also gives you plenty of surface area for the body mounts. One note, make it as long as you can, you may be able to reach the rear outer body mounts if the existing channels are in bad shape.
    I haven't done this myself, so take my opinion for what it's worth. "A bird in the hand is worth what it will bring".
  5. Brog
    Brog
    182
    Mar 31, 2003
    Chattavegas, TN
    Thanks, I'm going to pick up some steel this weekend.
    Brog :D
