Rear 3rd member + e-locker used pricing?
Discussion in '80-Series Tech' started by DanKunz, Sep 5, 2003.
  1. DanKunz
    DanKunz SILVER Star
    8,861
    Media:
    2
    523
    Feb 7, 2002
    Woodstock, GA
    What is the current used private pricing on a stock e-lockered rear chunk?
    I have a line on one for a certain amount and can swap that sucker right into my 91 using the e-locker control from http://www.inchwormgear.com/ ($75)
    What's the word?
    Thanks!
  2. cruiserdan
    cruiserdan SupportingVendor Emeritus Supporting Vendor Moderator
    20,564
    2,891
    Mar 27, 2003
    Surrounded by Cruisers from all over the world
    Dan,
    I have not tried to purchase a used locker rear diff. I can tell you that a new one lists for just under 1,300 bucks (off today, can't tell ya to the penny ::) ). Often junk yards try for half the new price. I would say anything over about 650 bucks is getting kinda close to what you could get a brand spankin' new one for (if ya know where to shop ;) ).
  3. DanKunz
    DanKunz SILVER Star
    8,861
    Media:
    2
    523
    Feb 7, 2002
    Woodstock, GA
    Aside from housing mods I am not too intimidated by the install.
    the price I have lined is way less than of your lowest price...may be worth it!!
    Thanks!
  4. Bradass80
    Bradass80
    220
    Jul 24, 2003
    Colorado
    sor only wanted $450.00 last i checked. :eek:
  5. cruiserdan
    20,564
    2,891
    Mar 27, 2003
    Guys,...guys,
    All I said was anything over 650 was a bit much, I wasn't trying to sell one for that ::) . I don't do used..... ;)
    I'd say 450 was very fair. :banana:
  6. landtoy80
    landtoy80
    5,668
    241
    Mar 13, 2003
    North Front Range, CO
    [quote author=Bradass80 link=board=2;threadid=4980;start=msg38183#msg38183 date=1062776609]
    [/quote]
    Where did you find it, on the SOR web site? I was looking on their site and couldn't find it.
    They are $500 at Cruiserparts but they are out of stock :'(
    If I could get a low mi one, I then wouldn't have to rebuild mine plus I would get a actuator that is not in 3 pieces 8)
    kurt
    It would be nice to go in with someone that needs the diff but the actuator and split the charge :-*
  7. DanKunz
    DanKunz SILVER Star
    8,861
    Media:
    2
    523
    Feb 7, 2002
    Woodstock, GA
    Kurt, I may have a line on a salvage FZJ80, will send owner your way if it all goes through.
  8. landtoy80
    landtoy80
    5,668
    241
    Mar 13, 2003
    I need a charcoal canister too
    thanks
  9. Junk
    Junk
    6,185
    23
    Dec 13, 2002
    buggerville nj
    I have a new rear elocker actuator sitting in my garage. :flipoff2: Not going to use it since the portals are going under this winter.
    Anyone want or need? :D
  10. landtoy80
    landtoy80
    5,668
    241
    Mar 13, 2003
    Is there a blue light price?
  11. Bradass80
    Bradass80
    220
    Jul 24, 2003
    Colorado
    I called them when i was quoted $450.
  12. sjpitts
    sjpitts
    720
    1
    Jun 9, 2003
    Mesa, Arizona
    Dan
    Doesn't your 91 have a SF rear end? For some reason I though the e-locker required a FF rear end.
    Otherwise I would love to put one in my 55.
    Jared
  13. cruiserdan
    20,564
    2,891
    Mar 27, 2003
    The e-locker can be installed in a SF axle, I do not know the specifics. Theferg is in the middle of doing something along those lines.
    D-
  14. landtoy80
    landtoy80
    5,668
    241
    Mar 13, 2003
    Downey sells a axle to make the conversion to SF.
    kurt
  15. Big_Moose
    Big_Moose
    426
    Aug 26, 2002
    I don't think the electric locker can be installed in the rear land cruiser semi-floating axle [could be wrong, whats new :flipoff2:]. The toy semi-floater requires the c-clip to hold the axles in place - so the locker will not fit.
    In fact, I'm getting like Junk, and I know it won't fit ;).
    It does fit the FJ front FF axles.
    - lock axle in locked position, slip in housing
    - replace a couple of diff studs, which need to be a little longer
    - install longer splined, short side axle, i.e. front, short side axle from a 70 series, Downey, CV Unlimited, etc
    - wire up the actuator, use factory actuator controllers / relays, or cable attachment
    Joe
  16. landtoy80
    landtoy80
    5,668
    241
    Mar 13, 2003
    The Downey kit is for 40 and 60 to add 80 third member using a cable to lock the diff. The kit comes with axle, cable and a block to mount where the actuator goes.
    Maybe it won't work on a SF. That wouldn't be the first thing Downey sells that doesn't work.
    kurt
  17. landtoy80
    landtoy80
    5,668
    241
    Mar 13, 2003
    SOR only has front diff with lockers no rears :'(
  18. DanKunz
    DanKunz SILVER Star
    8,861
    Media:
    2
    523
    Feb 7, 2002
    Woodstock, GA
    Well, the secret was I am trying to get a FF rear end w/o locker and the chunk with the locker to mate together.
    pricing is looking good too...who knows!!
  19. Junk
    Junk
    6,185
    23
    Dec 13, 2002
    buggerville nj
    [quote author=landtoy80 link=board=2;threadid=4980;start=msg38300#msg38300 date=1062796310]
    Is there a blue light price?[/quote]
    If that was directed towards me, yes, there is a blue light price. Send me an email or PM and I'm sure we can work something out so you'll soon have a locker in the rear. :D
  20. landtoy80
    landtoy80
    5,668
    241
    Mar 13, 2003
    [quote author=cruiserdan link=board=2;threadid=4980;start=msg38163#msg38163 date=1062772151]
    Dan,
    [/quote]
    Dan Is the under $1300 for the compleat thrid member; gears,bearings,case,actuator ect assembled ready to install?
