"rattling" steering wheel
Discussion in '100-Series Cruisers' started by bluecruiser, May 24, 2011.
  1. bluecruiser
    bluecruiser
    2,433
    641
    Jun 26, 2005
    Phx
    My steering wheel rattles. When I am parked with the wheel straight, I can move the wheel side to side, in the "slack", where the wheels do not turn and there is a rattle from inside the steering wheel (or where it connects?).
    If I am turning or have the wheel outside of the "slack" area, there is no noise. It seems that the slight "slack" or play makes a noise....any ideas on how to get into steering wheel and check what it could be?
    Thanks
  2. bluecruiser
    bluecruiser
    2,433
    641
    Jun 26, 2005
    Phx
    no ideas? Any ideas on how to look at the inner workings of the steering wheel?
    Thanks
  3. 2000UZJ
    2000UZJ Where's My Hammer?
    8,655
    116
    Oct 7, 2008
    Earth
    mine has a little slack when off and on flat ground. I think it's normal, a little play gathering at all the linkages. I could be wrong though. Driving it's fine. I don't have a rattle, but I can make it "knock" when I wiggle it quickly back and forth (no homo)
  4. bluecruiser
    bluecruiser
    2,433
    641
    Jun 26, 2005
    Phx
    the little bit of play is fine with me....the rattling type noise is kind of annoying. it will rattle slightly on rougher asphalt, speed bumps, etc.
    I just think something in there could be adjusted...
    thanks
  5. jgray
    jgray
    1,380
    24
    Dec 30, 2006
    Smithfield, VA
  6. 2000UZJ
    8,655
    116
    Oct 7, 2008
    Earth
    Creepy. Coming down the street with a fresh patch job it was some nice :.:.:.: style bumps. My wheel does it too. Just starte I guess.
    Sent from my iPhone using IH8MUD
  7. bluecruiser
    bluecruiser
    2,433
    641
    Jun 26, 2005
    Phx
    thanks for the info and the compliment...it has been rattling for awhile...it is just really starting to annoy me....
  8. justdifferentials
    justdifferentials Gear & Axle parts for ALL Toyotas new or old... Supporting Vendor
    1,456
    109
    Jul 31, 2006
    Washington
    steering noise
    Before you pull the steering wheel, check the column joint. there is a ujoint and a rubber damper joint. Hold the joint with one hand and rock the wheel, see if that is where it's coming from.
    Mine is a bit loose and more noticeable after Moab and the 2k+ mile trip. I just ordered a replacement, as well as an extra to keep on the shelf.
