Quick ? on 4 Speed Trans
Discussion in '40- & 55-Series Tech' started by zetasig, Jan 7, 2003.
  1. zetasig
    zetasig
    1,419
    Dec 4, 2002
    Hiding
    Will a LC 4 Speed Trans Bolt up to an F motor? I have a three speed currently and 3 speed Xfer Case. &nbsp:Do I need any special adapters?
    The Motor is a '68.
    What are the best trans, Xfer years if I can find one.
    Thanks again for your wisdom.
  2. Gumby
    Gumby Supamod Staff Member s-Moderator
    11,778
    307
    Dec 13, 2002
    Knee deep in hookers and gin
    You need the 4 speed bellhousing, but the bolt pattern on the block is the same.
  3. zetasig
    zetasig
    1,419
    Dec 4, 2002
    Hiding
    Sounds Good, Will any year 4 speed with the bell housing bolt in? or are their specific years that it will fit?
    Thanks again.
  4. woody
    woody Internet Fireman Staff Member
    10,331
    Media:
    303
    1,086
    Jan 15, 2002
    Toquerville UT
    74 until 83 FJ40 all are the same bellhousing bolt pattern..FJ60 I believe is the same too thru 1988
  5. zetasig
    zetasig
    1,419
    Dec 4, 2002
    Hiding
    Im a bit confused, the motor I have is a 1968 F. So I need to know which year bell housings match the bolt pattern
    Thanks
  6. woody
    10,331
    Media:
    303
    1,086
    Jan 15, 2002
    Toquerville UT
    the 68 motor pattern will match the tranny bellhousing from "any" toyota 3 or 4 speed tranny....to mate to your motor, you must have the matching bellhousing for the tranny.
  7. zetasig
    zetasig
    1,419
    Dec 4, 2002
    Hiding
    In other words the 4 speed I find Needs to have the bell housing too, and it will bolt up to my motor. any year will work?
    Your the man.
  8. woody
    10,331
    Media:
    303
    1,086
    Jan 15, 2002
    Toquerville UT
    exactly.....any year.... :D :D :D :D :D
    Now, don't forget that your 3-speed t-case will not just "bolt up" to the 4-speed trans without a special input gear and some other little stuff....
    :rolleyes: always something.....lol
  9. zetasig
    zetasig
    1,419
    Dec 4, 2002
    Hiding
    Yea I knew that part.
    Thanks for the Help today. :D
