Question on front axle rebuild...
Discussion in '40- & 55-Series Tech' started by glassman, Feb 3, 2003.
  1. glassman
    glassman
    5
    Feb 3, 2003
    Greetings...
    I am rebuilding my front axle/knuckles/ and had several questions.
    Is it worth doing the Marlin tack while I have the axles out?
    do you use two different types of grease on the rebuild?
    I see a post on the lcml right now where they suggest moly lube on the birf and high temp on the knuckle bearings??
    I have a gallon of high temp dino .. ready to go? I want to do the right thing, I don;t want to go back in for a while.
    I read Morgans piece on this but did not address grease type.
    Thanks
    Nice site Woodrow!
  2. zipp
    zipp
    85
    Feb 13, 2002
    Davis, CA
    The wheel bearings do need high temp grease- the standard black high temp variety. For packing the birfield and knuckle I used marine grade grease (used in boat trailers- it doesn't turn into soup when it gets wet- and it's blue too!). I was told to use the blue marine grease, or the red grease- I forget what the name of it was... But yeah, two different greases for the bearings and knuckles.
    I didn't do the marlin tack on mine- I probably should have, but I don't really plan on breaking it- so why would I need a quick, and easy way to change out a birf?? If you've got the welder and the know how, then just do it and get it over with. Compressing the inner snap ring on a birf is a pain.
    HTH- Zipp.
  3. Slowerthanu
    Slowerthanu SILVER Star
    1,326
    8
    Apr 23, 2002
    Bountiful, Utah
    What zipp said and do the Marlin tach for sure.
  4. woody
    woody Internet Fireman Staff Member
    10,333
    Media:
    303
    1,089
    Jan 15, 2002
    Toquerville UT
    I use marine grease on everything...it's good enough for trailer bearings, it's good enuf for my front Cruiser bearings, and it works for the knuckle/birf as well. One grease to carry on the trails too.
    My cruiser only sees rare/short road use tho...
