Azca
If there is a harder way - I will find it...
Getting very close to pulling the motor and thinking it through. My biggest question at the moment is the crankshaft pulley and when to remove/loosen it.
I am not pulling the transmission so I will have to use the crankshaft pulley to turn the flywheel to pull the torque converter clutch mounting bolts between the trans and engine.
That seems strait forward enough but then, I won't be able to use the starter trick to loosen the crankshaft nut. Am I stuck getting an impact wrench to pull it? The crankshaft nut just laughs at my 500 lb impact gun...
