PTO Gear Shift
Discussion in '40- & 55-Series Tech' started by IDave, Feb 19, 2003.
  1. IDave
    IDave
    7,174
    Media:
    1
    13
    Jan 3, 2003
    McCall, ID
    I'm in the process of installing a PTO gearbox (and winch) into my 9/70 FJ40. I haven't actually seen one of these installed, and I know some of you out there have them. What I would greatly appreciate is a photo or two of how the PTO gearshift lever is mounted/installed, or a good description. I assume it fits on the transmission tunnel, but I don't even know that for sure. Can anyone help me? ???
    IDave
  2. LT
    LT
    1,783
    26
    Apr 8, 2002
    Portland, OR
    I don't have a pic but the PTO lever in my cruiser was cut in the tranny tunnel. It's about prallel with the tranny stick. It's got a little felt liner around it but it keeps me warm during the winters..... tho in the summer is blows. Think it's time for a boot??
  3. IDave
    IDave
    7,174
    Media:
    1
    13
    Jan 3, 2003
    McCall, ID
    I have column linkage, so no transmission shift to look at. Must be on the driver's side of the tunnel, right? I mean, left? :D
  4. LT
    LT
    1,783
    26
    Apr 8, 2002
    Portland, OR
    Yes it is, if i can get my room mate to bring down his digital camera i'll take some pictures of what it looks like.
  5. IDave
    IDave
    7,174
    Media:
    1
    13
    Jan 3, 2003
    McCall, ID
    That'd'be great :D
  6. beanz2
    beanz2 Moderator
    2,124
    6
    Nov 16, 2002
    Dave,
    the shifter has a threaded pivot that screws into the transmission top cover. [​IMG]
    It only sticks out through the transmission tunnel, but there is a boot to keep dirt, dust and noise out like GreenWeeny said. In older cruisers there is also some sort of flap door that keeps the lever in place that attaches to the tunnel like part #9 on SOR's catalog: [​IMG]
    Dave
    (I got to say Specter does the cruiser community a big service by putting up these diagrams on line)
  7. IDave
    IDave
    7,174
    Media:
    1
    13
    Jan 3, 2003
    McCall, ID
    Hi, Dave.
    I've got the part about the pivot. But I've stared at that figure from the SOR catalog and I just don't see the hole that must be there for the lever to go through! There is a dotted line from the flap (discontinued-no longer available) that seems to go to solid tunnel cover. Is the hole just a slot, a circle? &nbsp:Does the pivot point rest on top of the tunnel, or does it ride underneath in a bracket? That's the sort of stuff I am trying to find out.
    Thanks!
  8. Ground Up
    Ground Up
    418
    Feb 1, 2002
    PNW
    IDave-
    The trucks that were originally supplied with the Toyota PTO had a slot in the Transmission Hump. The little oval flap door was used to locate the shifter in a nuetral position. I have the little flap door which I can take a digital photo of and send to you. I do not however have the hole in my transmission hump yet though. Otherwise I could send a rubbing of the actual hole and it's location.
    If someone out there has an original hump with the factory hole it would make life alot easier for people like us to add the correct size hole.
    The shifter pivot attaches to the shifter plate on the top of your transmission. If you have vaccum (sp?) shift then there was a plate that had three bolt holes to bolt to the transmission.
    Let me know if you want me to e-mail any pics.
    HTH!!
  9. IDave
    IDave
    7,174
    Media:
    1
    13
    Jan 3, 2003
    McCall, ID
    Sniper,
    That would be great if you would email pix of the oval flap.
    I do have the vacuum shift transfer case, but you say the plate fits onto the transmission. I'll have to stare at that a bit.
    IDave
  10. IDave
    IDave
    7,174
    Media:
    1
    13
    Jan 3, 2003
    McCall, ID
    Sniper,
    Thanks for the pix. I think I can put it together, now. &nbsp:Don't know what I'll do for a flap door, unless someone out there happens to have one. But it looks like something I can jury-rig.
  11. PHAT MAX
    PHAT MAX
    434
    Jan 30, 2002
    post the pics...im interested!
  12. IDave
    IDave
    7,174
    Media:
    1
    13
    Jan 3, 2003
    McCall, ID
    Here ya go: the hole in the hump
  13. IDave
    IDave
    7,174
    Media:
    1
    13
    Jan 3, 2003
    McCall, ID
    And the hinged flap:
  14. IDave
    IDave
    7,174
    Media:
    1
    13
    Jan 3, 2003
    McCall, ID
    And the shift lever on the pin/stud mounted onto the transmission top plate:
  15. Chef
    Chef
    1,972
    6
    Jan 24, 2003
    Columbia, MO
    IDave, is that the toyota three speed the shifter stick is attached to? I'm running an h41/early tcase on the rig that's getting my pto winch, and it looks like there's the same hole in the top cover, in about the same place...Alan, with two toyota pto's waiting to work their way onto the rig...
  16. IDave
    IDave
    7,174
    Media:
    1
    13
    Jan 3, 2003
    McCall, ID
    Alan,
    Its Sniper's picture, but I'm pretty sure its a 3 speed tranny. The schematic for the 4 speed in the chassis/body manual I have shows the same hole. Beyond that, I can't be sure. Exceptin' that in Specter's catalog there is a schematic for a PTO gearcase that has 2 instead of 1 shift levers. &nbsp:Don't know where that fits into all of this.
  17. Ground Up
    Ground Up
    418
    Feb 1, 2002
    PNW
    It is mounted on a three speed tranny.
    In regards to the double shift, they were for a rear mounted water pump. I assume for the fire truck model. I have the printouts from the Toyota dealer that shows the drive shafts for the rear, pretty interesting. I purchased the above shifter and pivot from SOR, as I remember $18. It took them sending two of them befors I got one that wasn't mangled. If your going to order one ask for Mark and have him find one that is clean.
    BTW SOR now sells the throttle cable kit for the PTO. It's a little expensive IMO.
    If anybody reads this and has a factory hole for the PTO shifter please let me know I would love o rubbing of it for a guide to cut in mine.
    Thanks!
  18. IDave
    IDave
    7,174
    Media:
    1
    13
    Jan 3, 2003
    McCall, ID
    Ahh, the throttle cable thing.  Excuse me while I vent, but since you brought it up I think I will.
     The kit SOR sells, or, for that matter any of the throttle cables they sell as parts, is the under dash model.  The FJ40, however, had an in-dash hand throttle with the PTO option.  I ordered several different used cables trying to end up with the in-dash version, but SOR kept sending the under dash, short cable type.  When I pointed out that the owner's manual, toyota repair manual and their own catalog show the cable is supposed to be in-dash, they claimed they researched it and said there never was an in-dash version!  :mad: Yet, all the literature says the under-dash was for the FJ45 only until 9/72.  Anyway, if someone out there wants a used underdash hand throttle, I've got a couple extra, cheap.  You need a special tab on your gas pedal to attach it to (that's what makes the kit) but it would be simple and cheap to jury-rig an attachment to your standard pedal.
  19. LT
    LT
    1,783
    26
    Apr 8, 2002
    Portland, OR
    Behold the PTO power :D
  20. LT
    LT
    1,783
    26
    Apr 8, 2002
    Portland, OR
    2 Cruisers at once!!! :eek:
