PS bracket for 2f engine and saginaw pump?
Discussion in '40- & 55-Series Tech' started by buckroseau, Apr 13, 2003.
  1. buckroseau
    buckroseau May I have another!!! SILVER Star
    3,307
    8
    Mar 29, 2003
    Northern Minnesota
    Hi,
    Wondering if anyone out there knows of the best place to get a bracket for a saginaw pump to mount to a 2F on my 77 FJ40? I see that BTB has one, but $175 seems aweful pricey for that little bit of steel?
    Any help would be appreciated, Thanks, Matt
  2. PHAT MAX
    PHAT MAX
    434
    Jan 30, 2002
    I did not even need a bracket...just hacked part of the smog pump bracket off and it fit like a charm! :eek: :G
    remind me to get pics!
  3. MD11Fr8Dog
    MD11Fr8Dog CM09 Eight Ball winner
    539
    4
    Apr 6, 2002
    Southern Pines, NC
    Get pics!!!
  4. Degnol
    Degnol
    8,123
    Media:
    16
    6
    Jan 22, 2003
    Kansastitty
    wdorry@yahoo.com makes a Sag pump mount that does not use the two front head bolts. It uses the three motormount bolts. The adjustment arm mounts on a stud (which he provides) on the waterpump. The whole thing was $85+ shipping and included all the hardware.
    I believe he is a machinist, and it shows.
    Ed Long :)
  5. buckroseau
    3,307
    8
    Mar 29, 2003
    Northern Minnesota
    Fatkid, I never even thought of using the smog pump bracket, that seems like a good idea.    I would like to see pics if you could email them to me or post them here.
    Ed, I tried > wdorry@yahoo.com < all I come up with is the yahoo web site.   Do you have a phone number ?
    Thanks, Matt
  6. Degnol
    Degnol
    8,123
    Media:
    16
    6
    Jan 22, 2003
    Kansastitty
    That is his email address. Try emailing him there. His sh!t is nice.
    Ed :)
  7. PHAT MAX
    PHAT MAX
    434
    Jan 30, 2002
    i will get pics tonite....i cant find the camera now! :eek: :cry: :dunno:
  8. axlechassis
    axlechassis
    237
    Mar 1, 2003
    Wasilla/Bangkok
    I used the one from JT outfitters. Seems to work well and is a pretty clever adjuster design. It does use the two front head bolts though. I there a disadvantage to that?
  9. Degnol
    Degnol
    8,123
    Media:
    16
    6
    Jan 22, 2003
    Kansastitty
    The biggest disadvantage I can see is violating the torque sequence on the head bolts. Is this really an important factor?. Well why would there be a sequence if it wasn't?
    I'm not trying to be a smart ass here, the question is legitimate. I know JTO makes some really nice stuff and turns out some nice products, so, no offense to anyone.
    This bracket allows for adjustment of the pump by itself. I've seen some that also run the alt on the same belt, but what if your pump belt is squealing, do you overtighten the same belt that is running your alt just to get the PS pump to stop making a noise??How do the alt bearings like it?
    Too many ways to skin a cat, only miles will tell. A longitudinal study, so to speak, might answer the question.
    Currently, I'm wrestling with Sag pulley off a GM or Volvo. The Volvo has the correct(read SAME) width pulley as the Toyo. But my rig has been running a narrower belt(SAE) on the wider pulley(s) with no excessive wear. Can get a Volvo pulley, but a bigger PITA to get. Any thoughts???? ??
  10. PHAT MAX
    PHAT MAX
    434
    Jan 30, 2002
    HERE YOU GO!!! :beer:
    Here you see where i cut off the front of the smog bracket.
    [​IMG]
    here is the adjustable part...just a triangular piece of steel bolted on to the pump (came on it, i trimmed it)
    [​IMG]
    Here is the back side, the new nut you see goes thru the smog bracket, and it is a stud that is part of the housing....simple!
    [​IMG]
    Here is a close up of that nut.
    [​IMG]
    and you guys thought i wasnt gonna come through! :G :bow:
    -Max
  11. MD11Fr8Dog
    539
    4
    Apr 6, 2002
    Southern Pines, NC
    Naw, I had faith in ya!! ;) :D Any problems with lining up the pulleys??
    Thanks
  12. PHAT MAX
    PHAT MAX
    434
    Jan 30, 2002
    nope, that was the beauty of it...the power steering pully is lined up better than the factory alternator one!! :eek:
    man did that turn out slick!
  13. fresno-lc
    fresno-lc
    47
    Mar 13, 2002
    Max I wouldent leve the pump mounted like that. Your gonna shere the stud right off. I had the whole smog pump bracket on mine and I shered bouth of the bolts my brother did the same thing. You would have been better off leaving the smog pump bracket intact and just grinding it down a little bit that way you could have too bolts in the pump. i will try to take a picture of what i did so they wouldent sheer. I used a chevy bracket that went arround the pump and I welded a pivit to it so the whole thing fits into the smog pump bracket. There is no chance of this thing comeing loose or shereing and it looks better too.
  14. PHAT MAX
    PHAT MAX
    434
    Jan 30, 2002
    I thought the same thing, and might weld a bracket to the front of the smog bracket. ah it will work out! :beer:
  15. cruiserbrett
    cruiserbrett Moderator
    2,438
    39
    Feb 19, 2002
    San Diego
  16. Degnol
    Degnol
    8,123
    Media:
    16
    6
    Jan 22, 2003
    Kansastitty
    :) Re: PS bracket for 2f engine and saginaw pump?
    OK, my real thoughts...
    The stuff looked pricey to me. Even though the factory uses the two DR side head bolts to mount the air cleaner, it doesn't seem like that is the best place to use for a mount.
    Never actually ordered anything from JTO, but don't want to trash them for the same reason. Bill Dorry makes some well designed, well constructed stuff, at a reasonable price, and I do own some of HIS sh!t, and it is quality... to the bone. I felt wimpy about buying something that I might have been able to make...got Miller 250, torch, bandsaw, grinders, etc, etc,...but what is your time worth???
    Sounds like the smog bracket can be made to work, but I ain't got one. A GM bracket, looks like it can be made to work, I ain't got one!
    I had several email conversations with Bill and was convinced.
    I'm going to spend ONE day, hopefully, tearing the front end off my '40 moving the alt to the pass side, replacing the waterpump, changing out the PS, installing a header, installing a new manifold with a fluid heat riser, changing the valve cover to a 2F(because I can't run the F cleaner after the PS conversion). So... I don't want to re-invent the wheel. I'm counting on bolting on the majority of stuff. Bill has given me full right of bitching it his stuff doesn't work right. I think it will.
    I feel better now...
    Ed Long :)
  17. MD11Fr8Dog
    539
    4
    Apr 6, 2002
    Southern Pines, NC
    Good to know!! I just noticed last week the slight misalignment of my alt. pulley!! I have two of those PS pumps, I should be able to make one fit using your technique!!
    Thanks!!
  18. PHAT MAX
    PHAT MAX
    434
    Jan 30, 2002
  19. MD11Fr8Dog
    539
    4
    Apr 6, 2002
    Southern Pines, NC
    Okay, got home late last night, and after doing some much needed work around the house today - snow shoveling, yard work, and some honey doos - I attempted to work out my PS pump mounting.  I'm using the smog pump bracket, I had to grind a small area for clear, but thats it (edit: Ooops, I lied, I also had to drill out the holes on the smog pump bracket and bushing to fit the 7/16th" bolts!! :D).   Looks like it'll be a piece of cake.  I just need to get some new bolts, 7/16, and some spacers/shims, probably using some plumbing pipe.  The smog pump adjusting/tightening arm bolted to a water pump bolt will work out as well.
    Here are a couple pics.  Tomorrow the pump gets cleaned up and I get the new bolts!  Its a Scout pump by the way!! Also, it looks like 1 bolt all the way through, but its not, they are two bolts from the Scout bracket!
    [​IMG]
    [​IMG]
  20. bigbluefj40
    bigbluefj40
    12
    Apr 21, 2003
    :D hey there i have one i can sell you i'll see if i can find the picture and send it to you.. :beer:
