- Thread starter
- #101
This weekends projects were rebuilding the rear drive shaft and starting to install the new Isspro gauges. It's kind of neat when you find something cool in a truck that came from the other side of the planet. I found these docs stuffed in between the stereo head unit and the storage bin below the stereo. I used google translate and it appears they are insurance docs of some sort.
When I removed the rear drive shaft last time I noticed that the diff side u-joint had a worn spot where the bearings would bind. I didn't notice and drive shaft vibrations, but after changing the u-joints I now can tell that there were vibrations and now it smooth as silk.
I also started to install the new gauges (egt, boost and trans temp). I drilled and tapped the intake crossover for the boost sensor.
Wrapped the boost sensor wiring harness and routed it into the cab through a grommet in the firewall.
I also installed the thermocouple pre-turbo. The Safari turbo flange has a pre-drilled and tapped egt port for the thermocouple. I ran the wiring harness along the inner fender then through the same firewall grommet as the boost sensor.
Then I started pulling stuff out of the dash in order to get ready for the gauge pod installation. The gauge pod hood that I ordered should be here this so I can start playing with the gauge mounts.
Temporary gauge pod... LOL! Gauges work perfect... wired directly to 24v.
After getting the gauges installed I took the truck for a drive. They worked perfectly. I never got past about 800F and the boost never got over 10psi.
So... I decided to remove this and turn up the fuel...
