Just ordered a FA7590 kit for my 85 pickup. Should be receiving it tomorrow!
Just finished resealing the knuckles on my 85 pickup. Went smooth and the kit was excellent and packaged well. Thanks!
We've been shipping these for a bit but I never had the chance to get them photographed and introduced. To my knowledge we are the only company globally offering a 7x Series kit designed specifically for those models that have Electric Locking Hub's. I know many delete the E-Hubs in favor of traditional AISIN hubs (and we can help with that conversion too!) but some prefer to keep everything stock and thus we assembled these kits with all of the correct seals, bearings and gaskets and all from high-quality Japanese and OE suppliers.
So if you have one of these:
We have one of these:
FA7X97E shown
FA7X97EKWB & TWB shown
Applications:
FA7X97E - 1/90-1/98 70 Series w/Electric Hubs
FA7X97EKWB - 1/90-1/98 70 Series w/Electric Hubs & Koyo wheel bearings
FA7X97ETWB - 1/90-1/98 70 Series w/Electric Hubs & Timken wheel bearings
More information on our many knuckle kit offerings here:
Product Spotlight: Cruiser Outfitters Knuckle Rebuild Kits
It would be awesome if your 40 series kits included or offered additionally gaskets for the Warn style locking hubs. As alot of us have these instead of aisin hubs. I know the story about these being dealer installed and not oem but it doesn't change the fact that's what we have. Thanks, Bill
We are seeing more and more worn/damaged spindles during the knuckle rebuild and/or wheel bearing overhaul process. Spindles should be inspected for wear at several locations:
1. Damaged or worn threads, this will prevent proper pre-load on the wheel bearings and can allow major failure.
2. Damaged bearing surfaces at the inner and outer wheel bearing position. If you can feel it with your fingernail, it's likely too much.
3. Damaged seal surface area, check for pitting or excessive groove.
4. Damaged spindle bushing/bearing, check for excessive wear, missing rollers, etc.
As such, we are stocking more and more spindle components from OE Toyota, High Quality Japanese manufactures and more. We carry complete spindles and replacement spindle bushings and bearings too!
FA60081OEM (OEM Toyota) & FA60080 (Joint Fuji Japanese)
Part# FA60080 - $145.00/each (new lower price!)
Joint Fuji Japanese Replacement w/Upgraded Spindle Bushing/Bearing. Fits 1/1990-12/1997 8x Series/LX450. Spindle bushing/bearing combo is pre-installed so no additional parts are needed. One required per side, two per axle.
Part# FA60081OEM - $227.50/each RETAIL @ TOYOTA IS $340.36
OEM Toyota Replacement w/Upgraded Spindle Bushing/Bearing. Fits 1/1990-12/1997 8x Series/LX450. Spindle bushing/bearing combo is pre-installed so no additional parts are needed. One required per side, two per axle.
Pricing current here:
Cruiser Outfitters
The kit is great Kurt. Works like a champ.
Only thing I might suggest on the E-hub kit is adding some form of Moly-Silicone grease for the slip ring. It's the only thing not included that isn't easily sourced at your local NAPA. I bought a big tube because I will use it elsewhere around the shop. But, that's overkill for a lot of people. A small 1 shot pack would cover the need.
I don't know why not. It's not like you need much. I was thinking about it from the stand point of someone who doesn't work on their vehicles all the time like some of us. Now they have this giant tube of grease that they don't know what to do with. I view it as souped up dielectric, so I will use it.
Did you ever source a hub face gasket for the Warns?Many have used the AISIN hub face gasket on the Warn's with very minor trimming, I know we've done that here in the shop. If I could find a suitable aftermarket gasket we could absolutely include them. Honestly we pack 100% of these kits here in the shop so it's easy for us to have a note to add the gaskets for Warns. Great suggestion, I'll work on it!
We don't stock just the axle kits and components, we stock the tools you need to complete the job. Hub (drum & disc) and knuckle stud sockets, springs-scale gauges, seal pullers, snap ring pliers, centering tool kits, brass drifts and more.
View attachment 1267667 View attachment 1267668
Do you currently have the hub socket for drum brake models? If not, do you know what size it is?
