Fellas, I'm replacing the original radiator with a Champion C1213. I understand the pros and cons of that, but am trying to get the 60 back on the road while I see if the brass rad can be repaired. Trouble is, I can't get the mounting brackets to mount flush on the C1213…the bolt hole for the fan shroud is too close to the bracket bolts (view in pic is looking up from the bottom of the radiator). Anybody run into this or can suggest a work around?
Thanks!
Thanks!
