Power Tank Mounting
Discussion in '80-Series Tech' started by Chris_Geiger, Jun 8, 2003.
  1. Chris_Geiger
    Chris_Geiger
    305
    Mar 28, 2003
    Today I spent a couple hours fabbing up a mount for my power tank. I sometimes camp in the back so I wanted to keep the floor open. I don't plan to use the 3rd row seats so I was able to start with the right side seat mount. I welded a plate and support bar to it for a little added strength. Now the tank is securely attached and no longer sliding around on the floor.
  2. Chris_Geiger
    Chris_Geiger
    305
    Mar 28, 2003
  3. - S.A. -
    - S.A. -
    350
    1
    Mar 27, 2003
    JERSEY
    Nice work!
    that is sweet looking!
    later..
  4. cruiserdan
    cruiserdan SupportingVendor Emeritus Supporting Vendor Moderator
    20,605
    2,983
    Mar 27, 2003
    Surrounded by Cruisers from all over the world
    It's about time somebody figured out how to make something useful out of those things :G EXCELENT IDEA.
  5. Chris_Geiger
    Chris_Geiger
    305
    Mar 28, 2003
    The other side seat mount is going to become the second leg of a vertical spare tire mount.
    Still trying to figure out something to do with the 3rd row seat belts. I just hate to toss good parts!
  6. Landpimp
    Landpimp GOLD Star
    14,682
    869
    Mar 14, 2003
    PNW
  7. Chris_Geiger
    Chris_Geiger
    305
    Mar 28, 2003
  8. Beowulf
    Beowulf
    12,534
    30
    Mar 27, 2003
    Somewhere in the foothills...
    John,
    Any way you could be convinced to post up some detailed pics of the FE brackets, including how the lower part of the mount is attached to the vehicle?
    Do you remember where you bought the brackets?
    -B-
  9. cruiserdan
    20,605
    2,983
    Mar 27, 2003
    Chris, I meant to ask earlier, Did you powder coat the finished product or rattle it? Also, would you consider making more if folks were to send you their seat brackets?
    Dan
  10. Landpimp
    Landpimp GOLD Star
    14,682
    869
    Mar 14, 2003
    PNW
    Na....that just the stuff thats always in there, I can stuff WAY more stuff in when camping, 2 action packers sit on top the black box(which is filled with parts/fluids/ect) another 2-3 packers fit in where the one is sitting. Box on the right is all tools. there is a 5 gal water can on the right side(open side window and insert pump) tons more stuff stashed away here and there. Most everything is bolted down and the cargo barrier keeps the rest from hitting me in the head(it might help)
    it weights 7000+ the way it sits.
    John H
  11. Hltoppr
    Hltoppr SILVER Star
    2,022
    Media:
    4
    4
    Aug 29, 2002
    Port of Indecision...otherwise Northern Arizona
    Wow, gear after my own heart! I thought I carried a lot of stuff with me!
    Couple of questions:
    1. How do you like your hood blackout? &nbsp:Did you do it yourself or have it painted at a shop?
    2. Where is the false roof mounted to the body?
    Thanks! Great Looking rig. You should post a couple of your pics in the "Fording Depth" Thread!
    -H-
  12. Landpimp
    Landpimp GOLD Star
    14,682
    869
    Mar 14, 2003
    PNW
  13. Chris_Geiger
    Chris_Geiger
    305
    Mar 28, 2003
    I just rattle caned it with the idea that if I liked it I could powder coat it in a few months. My working arrangements here give me full access to the shop only for working on my personal rig. I can't use the shop tools for anything other than working on my truck. At this time I am simply unable as I don't have a welder at home, however I am happy to provide information/photos as needed to help others create their own.
  14. cruiserdan
    20,605
    2,983
    Mar 27, 2003
    Chicken...... :G
     Oh well, it was worth asking about.  :tear:
    Um,........What if yours "broke" and you had to re-do it? :dunno:
  15. Hltoppr
    Hltoppr SILVER Star
    2,022
    Media:
    4
    4
    Aug 29, 2002
    And then it "broke" again....and again! :doh:
    -H-
  16. moralien
    moralien
    381
    Apr 17, 2003
    On the catwalk.
    Chris I like the idea and it looks good but don't the tanks have to be in a upright positon to work?
  17. Chris_Geiger
    Chris_Geiger
    305
    Mar 28, 2003
    Well I guess if it was stolen, i'd have to make a new one. What are the chances a theif would leave a stock bracket behind?
  18. Chris_Geiger
    Chris_Geiger
    305
    Mar 28, 2003
    Theoretically you don't want the liquid C02 coming out the valve and into the line. So running it inverted would be a bad thing. With the outlet facing up and the bottle laying down it's up high enough that the CO2 turns to vapor before getting into the line. Actually it works very well like this. I can reach all four tires without removing the tank. With the tank on it's side I can reach in turn the valve on and off easily.
  19. ovrroks
    ovrroks
    55
    Jan 14, 2003
    Could you modify the bracket a little to mount it at a slight angle to prevent any liquid CO2 getting into the lines?
  20. Chris_Geiger
    Chris_Geiger
    305
    Mar 28, 2003
    Yes it would be easy to make it at an angle by welding in a spacer, but it actually works very well as it is.
