Power steering pump rebuild AGAIN
Discussion in '80-Series Tech' started by Seminole, Apr 11, 2003.
  1. Seminole
    Seminole
    106
    Mar 28, 2003
    I know this was partially addressed on the SOR board, but... My question is: Mine is howling, not squeeling. Will the rebuild kit resolve this or does it just need bleeding. It is leaking at the reservoir but only seeping out enough to get the pump assembly coated with ATF. Was palnning on the seal kit to address the leak, if it is not worth it, I'll just by an OEM reman.
    Anyone else fix a howling PS pump?
  2. 92Cruiser
    92Cruiser
    121
    Mar 28, 2003
    Seminole,
    I have a rebuild kit I purchased for my 92 but ended up just getting a new pump put in. You are welcome to it if you want. Just let me know what your address is and I'll mail it out.
  3. Wrench
    Wrench One Bashed Up 80
    4,496
    179
    Mar 27, 2003
    The steering box is not leaking? Am I correct? Because mine is. :'(
  4. Seminole
    Seminole
    106
    Mar 28, 2003
    92cruiser-
    sounds like we have similar setups. I have 31 BFG AT's and no other mods except the OME. Mostly focused on repairs and updated maintenance for now. Definitely interested in the seal kit, will PM you with info and let me know how much $ for it + shiping. Was yours howling at idle? I keep trying to nail it down between the smog pump and the PS pump.
    Wrench-
    No leakage at the gear box. A little play in the top shaft that I adjusted most of it out. Thinking about a rebuilt box in the near future.
