Throwing this out there, I have noticed a leak from the power steering and wondering if anyone else has had this issue.
1997 4runner 157K, Midwest car.
As best I can tell the the leak is not coming from the res.. It is I think either coming from the hose or the box down near the driver side. I have searched the net and have not found anything.
Im wondering if its either the box itself, or the hose/connection going into the box. The leak was bad enough that all the fluid has leaked out. Its possible that the connection on the hose has corroded over time and road salt. But wondering if anyone has had this issue before I start pulling parts and replacing things. It is dry all the way up from the hose connection into the box up, but down from there its completely wet with fluid.
Im not sure if its common to leak from the box, or from the lower hose. Which I think is the high pressure hose?
Other than that, when I get the leak fixed, Is there a procedure to bleed out the system?
Thanks I would post photos but the fluid is all over the rack and pinion now and probably would not help..
