I'm looking for a "how to" on replacing the OEM power mast on a 97 LC. I can't find the FAQ and the Comcast link I found is broken.
I'm thinking this is a pretty common surgery. Anyone, have the recipe for me!
thanks,
jared
Replace it, put some lube on the cable and very carefully reel the antenna in manually.
g'luck, Dan.
I followed the easy directions on replacing the mast. I pulled the cable and mast out and it looks the same as the replacement (OEM) so I figure nothing broke off inside. I threaded the cable back in until I felt resistance, slid the mast in and retracted the cable with button on the console. (actually my 4 year old did)
PROBLEM: The mast won't go down all the way. It's about a foot up when retracted all the way. I have raised and lowered the mast with the console buttons 10 or so times and removed and replaced the cable and mast but it still won't retract completely.
Any advice???
Jared
