I've been thinking about this issue for some time and can't get an answer by myself as what I need to do with my car.
As it currently is, my 80 sits on a OME stock height heavy springs. I guess there is a little lift actually over stock setup, probably less than 1". 285/75-16 tires and I don't plan on going larger that that.
Always thinking about finances too, having the 1" body lift plus the spring spacers (as far as parts prices go) that would be a better alternative. But, I think there will be more labor involved as well, therefore more costs. I think I need to get new (longer) shocks too, right? So it may add up to the cheaper option.
I've looked at some new shocks for a 2.5" lift and they run around $450-500 range. Body lift plus spacers maybe $200. SO it comes really close to the price of a 2.5" kit (I've seen them around $750-800)
In either case I think I need caster correction no matter which option I choose. So this cost will be constant for either option, not counting it.
I understand wheel travel will not be improved by the body lift and spacers kit, I will just get height off the ground without the benefits of better off road capability. Longer spring and shocks will achieve that to a degree, sway bar disconnect too. I am not a heavy duty off roader, but trying to keep the bottom from scraping rocks and dirt.
