Pinion Bearing
Discussion in '80-Series Tech' started by landtoy80, Mar 31, 2003.
  1. landtoy80
    landtoy80
    5,668
    241
    Mar 13, 2003
    North Front Range, CO
    How do I remove the pinion bearing without dropping the dif carrier? Its a FF so the diff doesn't have a removable cover.
    kurt
  2. Chris_Geiger
    Chris_Geiger
    305
    Mar 28, 2003
    Making any change to the pinion bearings could change the R&P pattern. If your pinion is loose or is making noise it would be better to remove the third member and replace the bearings as needed then resetup the gears and do a pattern check before putting it back in. I could see how you might be able to get the outer bearing out without pulling the thirdmember but you cant reach the inner pinion bearing without pulling out the pinion.
