That's a cool bumper. Did you have it custom made?
Did you flip the rear springs in your cruiser?Here's my junk...
What size tires/ lift are you running?Here's my junk...
Not stock white... But... White with black oem split rims
255/85r16 tires (33" tall)
Spare is 34x9.5-15 TSL SS
Those are original Toyota split rims. You might be able to find those through a dealer, but they are dangerous to work on.That's a awesome looking 40! Who makes a 16 inch stock looking wheel?
Sent from my iPhone
"Dangerous to work on"
You are thinking of American semi and heavy truck multi piece rims
Toyota split rims are IMHO extremely safe in comparison ... The Aussies can attest to them
There are precautions to take ... Just like using jack stands under a truck... Take the necessary precautions you'll never have an issue... Ever
In 15" or 16" sizes split rims aren't very dangerous so long as they're assembled correctly and inflated slowly after mounting up, paying attention to how the tire bead is in the right place. It's just a matter of learning how to do it right, like most things. Around the world it isn't an uncommon sight to see people changing tires along the roads. They don't require levering the second bead over a wheel rim which makes changing tires relatively easy.
The reputation as dangerous comes mostly from accidents with the much larger wheels used on large trucks. Semi-trailer Freightliner large. With those it's hard to see what's happening as they inflate and with the higher pressures involved a ring coming loose during inflation can explode away with enough force to cut a man in half. That's why truck tire repair places have a cage they put the wheel in before inflating.
However, it's become the case that a lot of tire places in this country won't work split rim wheels. They don't want to take chances and their insurance companies often won't support them if they do.
