PCV Hoses
Discussion in '80-Series Tech' started by landtoy80, Jul 15, 2003.
  1. landtoy80
    landtoy80
    5,668
    241
    Mar 13, 2003
    North Front Range, CO
    MyPCV hoses and clamps were a bit loose. This could become a vacuum leak if left alone. The hoses weren't cracked so I just got new hose clamps. I also was going to replace the oil cap seal but a new cap is only a little more than a seal. TRD has a $$$ oil cap. I am sure that it will add 30+ hp to my 1FZ :D but not worth the extra $ :eek: I replace the spark plug seal when I had the valve cover off along with the valve cover gasket. This should stop at least any vacuum leak from the valve cover.
    I bet the valve cover seals/gaskets would be one passed over looking for a vacuum leak.
    kurt
    Just remove the oil cap whe the motor is runnung and see what it does??????????
  2. cruiserdan
    cruiserdan SupportingVendor Emeritus Supporting Vendor Moderator
    20,580
    2,898
    Mar 27, 2003
    Surrounded by Cruisers from all over the world
    Kurt, you are correct. Aside from being messy, it DOES create a vacuum leak. As does a loose engine oil dipstick.
    BTW, the TRD oil caps are billiet aluminum. DO NOT put yer sandwich clamps around one that's screwed into a hot motor :eek: .
  3. landtoy80
    landtoy80
    5,668
    241
    Mar 13, 2003
    Is the oil pan area or bottom end of motor under a vacuum?? I have a slow leaking #2 oil pan. If so I better get on or "under" it ;)
    kurt
  4. cruiserdan
    20,580
    2,898
    Mar 27, 2003
    The "crankcase" is vented by the PCV and is under moderate vacuum in a correctly functioning engine.
  5. landtoy80
    landtoy80
    5,668
    241
    Mar 13, 2003
    Now that I think about it, it would be under vacuum as when you add oil it drains down to the pan. I better fix the pan/s leak next oil change. And get a new dipstick seal too.
    kurt
  6. 96Cruiser
    96Cruiser
    543
    Media:
    2
    54
    Jul 14, 2003
    CHARLESTON WV
    speaking of the PCV......C-Dan,whats the p/n for a toyota pcv valve and the rubber grommet it plugs into?(mines a 1996,if theres a difference)
    thanks
    doug
  7. cruiserdan
    20,580
    2,898
    Mar 27, 2003
    The valve is a 12204-35040 and the grommet is a 90480-18001.
    [shadow=red,left]NOTE: I left a "M" out of groMMet[/shadow] ::)
  8. Beowulf
    Beowulf
    12,534
    30
    Mar 27, 2003
    Somewhere in the foothills...
    Doug,
    I'm sure you already know this but for those that are replacing the PCV for the first time, be very careful removing the grommet. They become brittle, crack, and fall into the valve cover when you try to remove them.
    -B-
  9. 96Cruiser
    96Cruiser
    543
    Media:
    2
    54
    Jul 14, 2003
    CHARLESTON WV
    C-Dan--thanks for the p/n's.....
    -B- yea,i had read that and wanted to get the valve and [glow=blue,2,300]groMMet[/glow]before i changed anything,that way i can be xtra careful when i take the old one out/off......... :D
    doug
