I'm starting a new thread so we don't have to scroll through banter to get to the juice.
Prices are not listed, mostly because they are free or dirt cheap. First come first served. PM me for pickup and I'll try to respond quicker than usual
Paul
FJ40 specific
2 3spd xfer w/ cracked case
4 3spd tranny’s, maybe 5
1 speedo cable (long)
2 clutch masters
63 brake master w/ metal can
4 slave cylinders
brake booster
1 mini truck master brake cylinder
64 clutch or brake master metal can
1 LC master
6 wheel cylinders
3 drive shaft ends
3 short drive shafts
2 long driveshafts
1 parking brake drum
3 drum axle housings
1 box Toy bearings
5 steering linkages
4 steering arms
63 front axle parts – ball and claw, inner/outer axle, hubs brakes, diff guts…
1 set rear axles course spline
68 hubs
63 steering wheel/column
2 sets of diff guts from locker installs (course)
1 set of early hubs
2 homemade roll bars 1 very, very stout, 1 pos that won’t fit under a top
1 set front hoops (straight)
1 skid plate
8 spare tire carriers, 7 from TLC’s, both sides
1 ½ rear tire carrier hinges (probably have the rest of it on one of the carriers)
5 sets springs if you want some add-a-leafs, or to play with hi-point steel
4 ubolt skid plates
7 bumpstops
lots of ubolts and brackets
shackles of many sizes
1 bumperette
LC bezel
LC turn signal
4wd behind the dash linkage
4wd vacuum switch
1 set old fender flares
1 set unfinished ½ doors
2 sets of rear ¼ panel diamond plates
2 corner flag holders
4 running boards
4 window cranks
4 lift back cylinders
1 p side door handle
1 box of windshield hinges and hood hinges
a hood latch
1 top of tool box (under seat)
4 tool box latches
1 rear top sill for hatchback
3 lc license plate holder
2 long, 2 short gas tank straps
1 pass side knee dash pad
1 outside door handle
1 68 hood vent cover (below windshield)
2 kick vents
2 wing windows
1 glove box door
2 door latch striker plates
1 shift knob, no sticker
2 TOYOTA emblems for rear
1 3 spd gears shift glove box instructions
1 wipe/wash switch
1 rear door striker plate
1 lights switch
dome light cover
1 rear heater
2 63 wiper motors and 1 newer wiper arm
1 heater blower
1 front heater and 1 core
1 LC ash tray
Rear bench seat – early
1 short rear seat frame
1 rear bench seat – more recently redone
SBC specific
4 sbc air cleaner housings – 2 are edelbrock triangular
2 sbc valve covers
1 sbc oil pan
round air filter
2 ph230 oil filters new in box
2 early 80s sbc vacuum distro
4 engine fans 1 new
2 sbc bellhousings w/ mounts (although 1 is broken)
2 sbc flywheels and clutches
4 clutch forks sbc
2 Ampco QW615 spark plug sets new
Miscellaneous engine brackets including serpentine setup
sbc water pump (core?)
3 sbc power steers boxes
1 sbc ps pump
1 sbc mechanical fuel pump
sbc column and linkage
1 sbc steering wheel
3 alternators 1 good w/ serpentine (92 blazer) 1 core 1 unknown
2 sbc motor mounts
Non Vehicle Specific
1 set square KC lites
8’ ¾ heater hose
fuel pump electric
1 retracting 5 point seatbelt
fake mini truck nerf bars
1 box of rearview mirrors
wire in alternator welder/110V DC supply (new in box, no instructions)
1 summit oil gauges mounted on under steering wheel plate that fits another (water) gauge
3 rpm gauges
water temp gauge (mechanical)
5 horns
1 steel wheel (fits chevy/tlc)
1 set of ez level 550 load levelers still in box (helper springs)
1 box of many colored lenses, a few are Toyota
3 tow hooks
1 ignition switch aftermarket
1 fan shroud
1 swing out 4runner/pup tire carrier (needs hinge)
Paul
FJ40 specific
2 clutch masters
4 slave cylinders
brake booster
1 LC master
6 wheel cylinders
3 drive shaft ends
2 long driveshafts
1 box Toy bearings
5 steering linkages
4 steering arms
68 hubs
1 set of early hubs
1 skid plate
4 ubolt skid plates
7 bumpstops
1 bumperette
LC bezel
LC turn signal
4wd vacuum switch
4 running boards
4 window cranks
a hood latch
4 tool box latches
2 kick vents
2 wing windows
1 glove box door
1 wipe/wash switch
1 lights switch
dome light cover
1 rear heater
1 heater blower
1 LC ash tray
SBC specific
2 sbc valve covers
1 sbc oil pan
round air filter
4 engine fans 1 new
4 clutch forks sbc
1 sbc ps pump
2 sbc motor mounts
8’ ¾ heater hose
fuel pump electric
3 rpm gauges
5 horns
3 tow hooks
1 fan shroud
