- Location
- United States
Parting this engine after importing it all the way from the UK and determining that it has very low to zero compression. So fantastic... Compression numbers on cylinders 1-6: 200psi, 20psi, 540psi, 520psi, 200psi, 330psi. My guess it was over-revved and there's a hole in the #2 piston. It does still rotate and none of the valves appear to be hung up. I guess we'll see what really happened when it all comes apart.....
I have all the accessories for this also minus the AC pump, please send me a PM with any inquires. Shipping will be at cost to you via FedEx if I can't fit the part into a USPS flat rate box. I will gladly post up pics on request. You can also contact me via text, Ross @ 360-305-6861
A few prices to get this going...
24V starter, tested, cranks like crazy: $225
Toyota CT26 Turbo, spins freely, bearings feel good, the impeller has a few small chips in the blades: $650
Toyota Alternator, includes pulley, I'll test before shipping to make sure it works: $150
Power Steering Pump with factory reservoir and line, no HP hose, FZJ hose will adapt: $200 SOLD
Toyota Vacuum pump with vacuum lines: $200 SOLD
Toyota Injector Pump, #759, P/N: 22100-17590: $300 SOLD
