painting in greenhouse, humidity issue
Discussion in 'Paint and Body' started by 90FJ, Jan 24, 2013.
  1. 90FJ
    90FJ
    955
    216
    Oct 24, 2012
    fellow mud member painting a shop railing in his greenhouse, outdoor temp 44* and cranked the greenhouse heat to 65*
    live in Oregon so it's pretty wet, after a coat of Rustoleum self etch and a coat of their 2X hammered finish he says he can scrape the paint off with his fingernail. not tacky though.
    I'm thinking by raising the temp in the greenhouse he took the humidity outside of desirable levels.
    is he better off applying another coat in the greenhouse at the same temp?
    turning off the heat and opening the doors and applying another coat at 44*?
    should the paint set up better over time once it has the ability to cure?
  2. Splangy
    Splangy
    4,887
    103
    Aug 4, 2009
    New Hampshire
    It might have something to do with the fact that he painted directly over self etching primer. You can guarantee yourself adhesion problems when doing that. There should be a coat of surfacer primer applied over the etching primer before topcoating. It might also have to do with the fact that he painted a car with rust-o-Leum!
  3. 90FJ
    90FJ
    955
    216
    Oct 24, 2012
    http://www.rustoleum.com/CBGProduct.asp?pid=397
    "Rust-Oleum® Self Etching Primer prepares bare metal, aluminum and fiberglass surfaces to promote maximum adhesion and smoothness of the top coat. This product is formulated to stop rust and is an essential step to achieve a professionally finished look."
  4. Joe_E
    Joe_E
    3,542
    121
    May 31, 2008
    the NJ word..
    What kind of heat?
    If burning propane, you are adding moisture to the air inside greenhouse.
  5. 90FJ
    90FJ
    955
    216
    Oct 24, 2012
    I think it's electric, but I'll ask him. Thanks poopdick.
