Rick or others with the seat extension mod, I am trying to repair DS electronic seat control fore and aft with new Gamiviti gears. With the seat extension mod in place there is no easy way to get the worm screws out that I can see without total seat disassembly. It's basically adjust for max flexibility on the worm gears, get the new gears in and then use the flexible cable between plastic housings to bend in the drive shaft between the two and secure.
I got the motor side going fine, but I've cracked one outboard plastic gear and it appears that I have managed to make toast of another one today. I get everything buttoned up. Install, the outboard gear gives it a couple of shots, it tries to go and then nothing. Yes I have the worm gears aligned.
What is the trick to disassembly on the seat rail extensions so I don't break my last new gear? I lost the instructions for the extension install. Going to " search " for them now on the forum. TX
