P0420 & P0430 codes: Catalytic inefficiency
Discussion in 'FJ Cruiser' started by BMThiker, Aug 10, 2012.
  1. BMThiker
    BMThiker I aim to misbehave SILVER Star
    6,471
    Media:
    9
    1,942
    Sep 19, 2006
    Atlanta
    So, I thought I'd share the little saga I've had with my FJC of late.
    Cliffnotes:
    I've been throwing P0420/P0430 (catalytic inefficiency right/left bank) codes since earlier this spring and now have to replace the exhaust manifolds.
    History:
    06/06 build date, purchased 07/06. 122,000 on the ODO. Daily driver and weekend wheeler (more like bi-annually these days:frown:). Heavily armored, meticulously maintained. Stock drivetrain except 4.56 gears and 35" KM2's. Never had a CEL come on before. Only overheated once or twice in the first year of ownership when radiator was blocked with mud (highest temp registered was 220). Stock air intake and exhaust - with only a minor modification to run the exhaust pipe behind the t-case instead of under it.
    Symptoms:
    I started throwing these codes every 500-600 miles earlier this spring. I asked around a bit and everyone said, "oh its just your O2 sensors behind the primary catalytic converters - a common Toyota problem. Just replace those and your CEL will go away."
    Diagnosis:
    When I replaced the O2 sensors ($100 each) the codes did go away for about six weeks. Ever since then, the frequency of the CEL coming on has increased. I've been scanning and resetting the codes with my ScanGaugeII. Usually it would only set off the left bank or the right bank at any time the CEL came on. I think once it registered both left and right at the same time.
    I've got to pass emissions next month. Now they come on every 30 miles or so which makes it impossible to pass the "readiness" test at the emissions center. The readiness cycle of your ECU is around 50 miles or so of mixed highway/city driving. Every time I delete the codes with the ScanGaugeII, it resets the readiness cycle of the ECU. If the ECU is not "ready", you fail the emissions test by default - kind of like a DQ in racing speak. The next test was to measure the temperature of the exhaust going in and coming out of the primary cat - done with an infrared/laser temp gauge pointed at the exhaust pipe before the cat and after the cat. If the cat is working properly it should be hotter (delta of 100* or so) from catalyzing the gases on the back side. Mine was reading an average of 650* in and 650* out. So that definitively narrows it down to the primary cats not working at all.
    Anatomy and Cure:
    The primary cats on the FJC are integrated into the exhaust manifold. No one makes a direct bolt on replacement other than Toyota. If I go aftermarket, then I'm skyrocketing my costs with JBA headers and Magnaflow cats. I ordered new manifolds and gaskets from Sam at Lowe Toyota on Monday and hope to have it all :wrench:'d out this Saturday.
    I'll update post surgery. If you're lucky, I'll even get a few pics of the procedure. :banana:
  2. 1911
    1911 chupacabra SILVER Star
    3,849
    515
    Aug 11, 2006
    Parker County, Texas
    How many miles on your truck Rick? I'm hoping my cats aren't plugging up or otherwise going bad. Good luck with the R&R; looks like tight quarters in there to get to the manifolds.
  3. holmanm
    holmanm
    83
    Nov 18, 2007
    Missouri
  4. 1911
    3,849
    515
    Aug 11, 2006
    LOL, yeah I guess I could have read with a little more comprehension!
    I've got 130,000 on mine so like I said, I hope the cats aren't going too.
  5. BMThiker
    6,471
    Media:
    9
    1,942
    Sep 19, 2006
    Atlanta
    The install went fairly smooth, roughly 5 hours under and over the engine bay. First thing to do is hose all bolts/studs with PB blaster or AeroKroil the night before and more the day you begin wrenching. I got the manifolds uninstalled in about two hours and realized I should have removed the front drive shaft first. It is necessary to make room for the manifold on the driver side to drop out the bottom. You also need to unbolt the flange at the back of the Y-pipe. This will allow the 2 foot section of pipe to be displaced while you wrangle out the passenger side manifold. Two socket sizes are used: 14mm with various extensions to disconnect the exhaust flanges and anchor brackets; and 12mm to remove 6 nuts on each manifold. I used a deep socket on a 3/8" drive for the manifold nuts. The longer your socket drive, the better for breaking them free, but a shorter drive is easier to maneuver the rest of the threads. Once the manifolds are loose you can access the O2 sensors' harnesses which require a strong squeeze of the clasp facing the firewall to unhitch. Once the manifolds are extracted use a 22mm wrench to swap them into the new ones.
    I think I spent more time removing my skids than I did removing the manifolds. Ditto on the installation process.
    Headed to the recyclers.
    The new stuff.
    All buttoned up.
    tappity-tappity from my Android device
  6. BMThiker
    6,471
    Media:
    9
    1,942
    Sep 19, 2006
    Atlanta
    a few more pics from the install...
    part numbers for gaskets - same #'s left and right.
    [​IMG]
    Soak in AeroKroil/PB Blaster and uncouple this flange on the passenger side. Also, leave all flanges loose until you get both manifolds into place on the block. I started to bolt this flange back too early and had to undo it again to get the pass side manifold to seat properly. You can also see the vestiges of my old Y that got relocated further back when I moved the exhaust pipe going under my t-case to go behind it.
    [​IMG]
    passenger side manifold going in
    [​IMG]
    my wife helping out
    [​IMG]
    Pass side in place
    [​IMG]
    Driver side in place. Now you can start bolting all the flanges together.
    [​IMG]
    You may notice the hanger bracket on this side is missing. I had to remove it when I replaced my starter earlier this summer and I sheared the bolt off in the old manifold when I tried reinstalling it after the starter went in. I have left it out for now because I honestly don't recall where I stashed the bracket. But the good news was that it was one less thing I had to move in order to wrangle the manifold in and out. I did not have to move the pass side bracket (truthfully I couldn't get it out), but it did require a little more muscle to get the manifold past it on both the extraction and installation.
  7. Sam Stewart
    Sam Stewart No longer kicking boxes... Supporting Vendor Moderator
    3,901
    Media:
    402
    339
    Sep 30, 2011
    Atlanta
  8. 123ROBERTELEE
    123ROBERTELEE
    1,158
    Media:
    3
    81
    Aug 22, 2011
    Baton Rouge LA
    Thanks for the pics and write up!
  9. BMThiker
    6,471
    Media:
    9
    1,942
    Sep 19, 2006
    Atlanta
    Put about 90 miles on it since Saturday night and, so far, looking good.
  10. Sam Stewart
    3,901
    Media:
    402
    339
    Sep 30, 2011
    Atlanta
    Awesome! :D
  11. Fireman
    Fireman SILVER Star
    4,303
    440
    Sep 5, 2003
    Iowa Park. TX
    And did this fix it for real?
  12. winnie
    winnie SILVER Star
    895
    191
    Nov 19, 2013
    Ont - Canada
    ditto re the great write-up ... good reminder about soaking with pb blaster ...
  13. Fireman
    Fireman SILVER Star
    4,303
    440
    Sep 5, 2003
    Iowa Park. TX
    PB blaster and Kroil are your friends.
  14. BMThiker
    6,471
    Media:
    9
    1,942
    Sep 19, 2006
    Atlanta
    Sorry, @Fireman, didn't have alerts coming though on this thread. But yes, long term results are still positive. No codes since this episode.
  15. AKcruiserfreak
    AKcruiserfreak
    2,290
    10
    Jul 10, 2006
    North Pole, AK
    Great writeup @BMThiker! I'm bumping this for purely selfish reasons! I had no idea you did a writeup.
    TK
    BMThiker likes this.
