semlin
curmudgeon
- Thread starter
- #21
Okay, I drained off the remaining excess diff fluid in my front diff this weekend . Another 250 ml or so came out so it was a total of 3/4 of a litre overfull. I also installed a diff breather extension on the front axle (thanks to Beowulf for the plans). There was no blockage at all in the old hose or the valve. On a sunnier day this time, the gear oil was slightly transparent and had a hint or tinge of green but no debris.
I didn’t change the diff oil because I couldn’t find SAE 90W anywhere in town. I notice at least one on the board running on the 80/90 that is recommended in the FSM below minus 18 degrees and good up to 10 degrees celsius. It is hotter than that here! 80/90 is readily available in synthetic or dino and is what the Toyota dealer told me they would use. The only other option I can find is SAE 90 marine gear oil (lower end) which is dino and a tad pricey but available and meets the API GL 5 standard.
So, I assume gears are gears and gear oil is gear oil but maybe someone can tell me whether I should use 80/90 or the marine stuff.
Also, I tried to check the transfer case – %$$&*@ grease monkeys have aired it up so tight I can’t get it to turn.
