Overfill of Brake Reservoir
Discussion in '100-Series Cruisers' started by Turkeypen, Dec 4, 2008.
  1. Turkeypen
    Turkeypen
    1,068
    13
    Dec 21, 2005
    Weaverville, NC
    Wife took the 2000 100 to dealer yesterday for express lube. They overfilled the brake reservoir and there was about 2 oz's of brake fluid on the garage floor this morning and the VSC ABS lights came on. The drip line goes over the top of the reservoir, crosses some wires, down the inner fender, along the axle and to the ground.
    Took it back to the dealer and they are hemming and hawing. Anyone know what problems could be caused by overfilling brake reservoir?
    Real time help needed to keep the dealer from coming up with excuses.
  2. Trunk Monkey
    Trunk Monkey Moderator
    8,099
    387
    Apr 27, 2003
    Salt Lake City
    Not much, maybe air in the system. If they offered up a full bleed you'd be good. And a wash.
  3. Turkeypen
    Turkeypen
    1,068
    13
    Dec 21, 2005
    Weaverville, NC
    Thanks Trunk Monkey.
    They just called back saying they pulled code C1231 and that I need both a steering angle sensor and a new ECU. Were looking at a couple of thousand . . . .
  4. Trunk Monkey
    8,099
    387
    Apr 27, 2003
    Salt Lake City
    Wow. Not what I would expect from the resevoir burping or air in the system.
  5. 1loudLX
    1loudLX
    9,402
    Media:
    23
    26
    Jan 7, 2006
    through the river and over the woods.
  6. Turkeypen
    Turkeypen
    1,068
    13
    Dec 21, 2005
    Weaverville, NC
    Getting in my 98 to go pick up the 2000 right now. Talked to my independent mechanic and he said "it's always a bad sign when the dashboard lights up after an oil change." He thinks it maybe as simple as a wire that was knocked loose or fouled. Taking it there right now. Will not replace the ECU as these come back (when tested at factory) 90 percent of the time as still good.
  7. spressomon
    spressomon glutton Moderator
    12,069
    Media:
    13
    646
    Jan 9, 2005
    Everywhere
  8. cruiser100
    cruiser100 Comfortably Numb
    449
    2
    May 30, 2007
    NE Atlanta, GA
  9. 1loudLX
    1loudLX
    9,402
    Media:
    23
    26
    Jan 7, 2006
  10. Turkeypen
    Turkeypen
    1,068
    13
    Dec 21, 2005
    Weaverville, NC
    I asked the same question and the Toyota guy said it was in the steering column inside the cab.
    Just got back from the idependent mechanic and he said he would look at it in the next day. His best guess at this time is the $8 an hour Toyota mechanic in the express lube knocked something out when he was under the car yesterday.
    I trust my independent shop as they are former Toyota mechanics who formed their own shop some 20 years ago. (The oil change at Toyota is a loss leader, so I usually take advantage of that service. Well, at least I use to).
    When I told the dealer not to touch it and I would pick it up, that hit a raw nerve with them . . . :D
  11. uHu
    uHu Shamowang
    1,419
    76
    Nov 27, 2005
    Oslo, Norway
    Note on checking brake fluid:
    Level to be checked without pressure in the booster.
    Means: With ignition off, press the brake pedal fully in about 25-30 times. Then check fluid level.
