I've got a problem with the output drive flange from my Orion case. I've moved the transfer case back a couple inches via AA extended adapter to help with front driveline clearance issues to the TH350 oil pan. In moving the transfer case back that much I've forced it almost right up against the crossmember for my rear linkage. Imy in need of a few suggestions on fixing this.
Thank you.
Thank you.
