Only runs w/ jumper wire from + coil to battery
Discussion in '40- & 55-Series Tech' started by burnt03, Jun 20, 2003.
  1. burnt03
    burnt03
    259
    1
    Oct 1, 2002
    Peachland, BC, Canada
    '78 FJ40 w/ 2F is acting up again
    Will only run w/ a jumper wire connected from the + side of the coil to the + side of the battery.
    Any ideas what might be wrong here?
    Thanks
  2. Gumby
    Gumby Supamod Staff Member s-Moderator
    11,778
    308
    Dec 13, 2002
    Knee deep in hookers and gin
    Re: Only runs w/ jumper wire from + coil to batter
    Could be the igntion switch, but I would try the ballast resistor first.
  3. burnt03
    burnt03
    259
    1
    Oct 1, 2002
    Don't suppose you'd have a pic of this.  I'm not sure exactly what it might look like...
    Actually, let me rephrase that... I know what they look like generally, but I don't seem to have anything of the sort in my truck.
    Instead I have some a light pink wire that says "ignition resistor wire" or something of the sort..... do I have to replace this wire or...?
    We tried bypassing this wire w/ a conventional ballast resistor but still no dice...
  4. toddslater
    toddslater SILVER Star
    1,498
    2
    Oct 31, 2002
    Kennett Square
    Just posted a pic in your other thread about this..but between then and now I noticed yours is a 78...semi transistorized. I'd replace the pink wire with a new one.
  5. burnt03
    burnt03
    259
    1
    Oct 1, 2002
    Tried a wire from where the pink wire begins w/ a resistor inline directly to the + side of the coil
    Still no dice.
    So check a little farther up the wire towards the ignition and notice one of those little connectors that toyota made impossible for people to get apart
    Took it apart and the IGN tab was melted. Changed that and it fixed it.
    Wheeeeeeeeeeeeeeeeeeee
    Just thought I'd post this in case someone in teh future has a similar problem
    Thanks for all the help guys
