Ed,
226 is when the A/C compressor cuts out. Certainly hot. IIRC you do not have forced induction? If you do not, something is NOT right IMHO. You should not get hot, even towing, with a stock motor. The 146 degree air temp is believeable as the air is drawn in thru the fender and the air cleaner assy before it hits the mass airflow sensor. I think you should flush the block and toss out the radiator and replace it with the 93-94 3 row brass radiator. You should also take a hard look at the fan clutch. As a bandaid, you can pull the hills with the A/C off and the heater on "high". Roll the windows down and hold yer nose. It does help.
Dan
Dan
