oil leaks
Discussion in '40- & 55-Series Tech' started by bad_religion_au, Jul 5, 2003.
  1. bad_religion_au
    bad_religion_au
    2,212
    Apr 24, 2003
    ok guys what's the easiest way of hiding an oil leak. i know i gotta do it properly soon, but the road worthy needs to be obtained in a week or so. and what's the best method of getting the oily stuff off the engine and leaf springs next to it. my degreaser seemed to do bugger all
  2. thorvald
    thorvald .......
    1,569
    Media:
    19
    23
    Aug 18, 2002
    on the ice, wyoming
    do you mean fix? or hide?
    why would you want to hide a leak?
  3. IDave
    IDave
    7,174
    Media:
    1
    13
    Jan 3, 2003
    McCall, ID
    Don't know what your degreaser is, but we have all sorts of brands of ammonia based stuff here thats supposed to be environmentally safe. Not as good as the organic solvent stuff, but hey. Here, the ammonia stuff is purple. I use that, then get out the high pressure wand at the drive through car wash and hose away. Probably take several applications of Purple.
  4. IDave
    IDave
    7,174
    Media:
    1
    13
    Jan 3, 2003
    McCall, ID
    Then, of course, you do want to fix those leaks. May just be a leaky rocker cover gasket: they often leak in back where it is hard to see, but they are pretty simple fixes.
  5. bad_religion_au
    bad_religion_au
    2,212
    Apr 24, 2003
    well i may not have the reddies or the time to fix before the check, and they make a huge deal out of it here. it will be fixed. i'm sure it's a rocker cover gasket, and an oil tray gasket, but with that, new exaust, new shocks, new side fence on the house, new bullbar, and new shackle rubbers, both my time and my wallet can only stretch so far, rest assured cruiser fans, i'm not about to drive it into the ground. the degreaser i've got is purple... can't get it to a car wash... not allowed to drive it on the street untill RWC is issued. can't even take it to a mech without getting a tow truck to take it (too heavy to be towed on car trailer)
  6. CruisinGA
    CruisinGA
    6,163
    8
    Mar 27, 2003
    Georgia Tech
    Get a towbar and flat tow.
  7. bad_religion_au
    bad_religion_au
    2,212
    Apr 24, 2003
    flat towing is illegal in australia from what i can gather.  if i'm going to break the laws, i might as well drive it there.
    new muffler, oil leaks, new bullbar, adjust the front brakes again, new shock rubber (done), check all 10 seatbelts for fraying, replace bolt on seat that makes it wobble, and hopefully i'm done. all this in less than a week. (and tonight i turned the lights on to look for any tools i left on the lawn, a headlight bulb blew
  8. brian
    brian SILVER Star
    7,343
    770
    Feb 7, 2003
    lebanon,pa
    just remeber one thing, if a cruiser isn't leaking oil.... you better make sure there's oil in it. :D
  9. bad_religion_au
    bad_religion_au
    2,212
    Apr 24, 2003
    brian... too true  :D   but not to worry, the HJ doesn't start without oil... well it starts then 2 seconds later there's a click, like a relay, and it stops.  could it have an oil pressure trigger or something.
    unfortunately the roadworthy guys don't like it when they're spilling the black stuff everywhere.
    and brian, i guess from your sig your a toyota fan
  10. s79bj40
    s79bj40
    359
    Feb 10, 2003
    Brisbane
    after a couple of drivetrain oil seal changes, my cruiser doesn't leak a drop. cop that.
    and the EDIC is supposed to have an oil pressure switch which shuts fuel off in case of no pressure.
    sam
  11. bad_religion_au
    bad_religion_au
    2,212
    Apr 24, 2003
    "and the EDIC is supposed to have an oil pressure switch which shuts fuel off in case of no pressure. " :D
    thought it was something like that. now for the anagram illiterate, what is EDIC?
  12. s79bj40
    s79bj40
    359
    Feb 10, 2003
    Brisbane
    electrical diesel injection control
    the little arm that comes off the top of it moves the fuel governor from off to normal to rich. When starting it moves to the rich position for a while, then clicks back to the normal position. I just read somewhere that it also shuts off the fuel when the temp gets too high as well.
    Sam
  13. bad_religion_au
    bad_religion_au
    2,212
    Apr 24, 2003
    thanks. i don't know how hot too hotr is, my thermostat broke a year ago, and temp went off the scale (wasn't watching. still ran though. funiest thing was i could open my thermostat (and therefore return to normal op temp) by turning on the heater. became part of start up tradition till i got motivated to fix stuff
  14. bad_religion_au
    bad_religion_au
    2,212
    Apr 24, 2003
    well guys wish me luck, going to get the Road worthy test. don't know how it'll fair :'( i almost got a under the table one, nudge nudge, but the guy went out o fbusiness a couple of weeks ago
