Oil leak from flywheel cover?
Discussion in '40- & 55-Series Tech' started by burnt03, Jan 10, 2003.
  1. burnt03
    burnt03
    259
    1
    Oct 1, 2002
    Peachland, BC, Canada
    On my '78 FJ40, the flywheel cover seems to be seeping oil.
    (if the flywheel cover is the metal plate w/ the rubber "plug", that is)
    What's the deal?
    Thanks
  2. Halo3
    Halo3
    84
    Oct 11, 2002
    Denver, CO
    More than likely that "moistness" is either from the rear main seal or the tail-end of the oil pan/seal. I've got the same thing happening...so join the club!!
    BTW, from what I've read, it doesn't sound like the rear main seal will be an easy project...sounds like the tranny has to get dropped.
    Maybe some of the more knowledgable 2F people can give us some insight.
  3. Gumby
    Gumby Supamod Staff Member s-Moderator
    11,778
    307
    Dec 13, 2002
    Knee deep in hookers and gin
    probably rear main or front trans seal depending on the type of oil. Be sure the oil is not from the rear of the valve cover. I've many, many misdiagnosed rear mains that were v/c gaskets. Like anyone who has fixed a leaky roof can tell you, fluid can run all over before it drips off.
  4. burnt03
    burnt03
    259
    1
    Oct 1, 2002
    Hmmm, good suggestion... I'll check that out
    Thanks
  5. Erics75
    Erics75
    81
    Jun 14, 2002
    Like Todd said check the valve cover first. If it's the rear main seal it's one piece and you will have to remove the tranny and flywheel, drop the oil pan and lower the crank a little. You shouldn't have to fully remove the crank, just loosen the main bearings ( somebody correct me if I'm wrong ). If you have lots of mileage on your engine then I would wait to rebuild the engine before just changing the seal.
  6. Mavric1298
    Mavric1298
    163
    Oct 28, 2002
    Deff. the rear main seal, or one of the others that were mentioned. Its not that hard of a thing to replace, just have to drop the tranny :D
