Oil indicator
Discussion in '80-Series Tech' started by Keep, Jun 3, 2003.
  1. Keep
    Keep
    251
    1
    Mar 27, 2003
    Chapel Hill, NC
    Today while accelerating onto the interstate my oil level (or temp?) indicator lit briefly. Aside from the obvious (oil level) what might cause this?
  2. Brentbba
    Brentbba Former Golfer SILVER Star
    9,824
    321
    Mar 27, 2003
    OC, CA
    Mine the two or three times it's happened in 9 years has always been the oil level. Oil is still at the bottom of the stick, so you've still got plenty, but throw in a quart after you've checked your level. Cheapest car insurance available.
  3. cruiserdan
    cruiserdan SupportingVendor Emeritus Supporting Vendor Moderator
    20,564
    2,891
    Mar 27, 2003
    Surrounded by Cruisers from all over the world
    Was it the aladin's lamp looking indicator?
    That is the level lamp. It means that you are about 2 quarts low :ugh: If the stick shows full, it may be a bad float.
  4. Keep
    Keep
    251
    1
    Mar 27, 2003
    Chapel Hill, NC
    Thats the one... must be a bad float. Any idea what I'm looking at for a replacement?
  5. Junk
    Junk
    6,185
    23
    Dec 13, 2002
    buggerville nj
    Cdan - I thought that read oil pressure and not oil level. Have I pulled boner or is that right?
  6. cruiserdan
    20,564
    2,891
    Mar 27, 2003
    Junk,
    It indicates oil level in the pan. It comes on at about 2 quarts low. I have seen it on in mine at an EXTREME nose down angle in Moab twice.
    Keep, I will check that in the morning for you and send you a PM with the info on the float. It is bolted to the upper oil pan on the LH (USDS, Beo) side, about in the centerline of the engine.
    I'm parched :beer:
  7. Beowulf
    Beowulf
    12,526
    30
    Mar 27, 2003
    Somewhere in the foothills...
    >> I have seen it on in mine at an EXTREME nose down angle in Moab twice. <<
    And at least once in the Rio Puerco. :G
    -B-
  8. cruiserdan
    20,564
    2,891
    Mar 27, 2003
    -B-
    Yup, Father's day run last year.......... :G
    Now, that was a STEEP incline....no?
