Oil filter question
Discussion in '80-Series Tech' started by firetruck41, Apr 16, 2003.
  1. firetruck41
    firetruck41
    5,732
    10
    Mar 27, 2003
    Camas, WA USA
    My toyota dealer did not have the 90915-20004 in stock, which was recommended by someone on this board, they did however have a 90915-20002 which supposedly preceded the 20004. It says 1UZ-FE and 3ZFE for aplication but not 1FZ-FE. Question: will it work the same? Should I order the 20004? Should I just get an aftermarket filter? This is my first oil change on it, going to use Mobil 1 10w-30.
  2. semlin
    semlin rocker
    5,209
    Media:
    1
    324
    Mar 27, 2003
    north of 49
    big good filter 15600-41010
    small good filter 90915-20004
    lousy filter yzzb5
    According to my garbled memory, the big good filter was original equipment, the small good filter was introduced to reduce start up rattle, while the lousy filter was introduced because mall cruisers complained about the price. &nbsp:Don't know any others, but my cruiser came with a mopar filter on it so if you want to experiment, fill your boots. I recently ordered a 20004 without problems even though they did not show it as available in Canada. It took 2 days.
  3. moralien
    moralien
    381
    Apr 17, 2003
    On the catwalk.
    I would go with the small toy OEM filter. If you’re local dealership will not play ball then call John Hocker @ Sierra Toyota or Jeff Watson @ Jay Marks Toy. Yes you will pay shipping but no taxes and both dealerships will serve up a TLCA discount. Just get at least 3 or 4 so you don't have to worry about it for a while.
  4. firetruck41
    firetruck41
    5,732
    10
    Mar 27, 2003
    Camas, WA USA
    I found some info in the archives on the 80scool list, the 20002 is good for a cruiser, it is just an older version of the 20004. So I used it, fit fine. Now running Mobil one 10w30. &nbsp:Does anyone else have trouble reading the dipstick on these? :-/ The oil is so light it's hard to see (not just synth, it was like this before)I took about 5 or 6 readings to make sure 8)
    Also changed the pcv valve and grommet, thanks for the tip from a member in a previous post about buying a grommet with the valve. The rubber did break and dropped a piece into the cover but I was able to fish it out with a scribe. Replaced it so now all is good.
    I want to change the plugs as well, is there a special tool for LC's to remove the plug wires? I didn't use a flashlight yet to look down the hole, but I tried pulling the plastic around the wires and it didn't move the wire from the plug. I didn't want to pull on the wire itself since I've ripped wires before in other cars, and a new set is $60-$130 and 5 days wait.
  5. Beowulf
    Beowulf
    12,534
    30
    Mar 27, 2003
    Somewhere in the foothills...
    Ben,
    >> Does anyone else have trouble reading the dipstick on these? <<
    Yes, but I have trouble reading just about everything the last few years. 8)
    >> ... thanks for the tip from a member in a previous post <<
    >> about buying a grommet with the valve. <<
    You're welcome. :G
    >> is there a special tool for LC's to remove the plug wires? <<
    I have seen these in auto parts stores though not LC specific. Haven't tried them though. They are shaped like an "L" with an insulated groove on one end.
    -B-
  6. BMT
    BMT
    325
    Apr 1, 2003
    I have actually switched to the K&N oil filter. After about two oil changes (depending on how dirty the oil and motor are) you can hardly tell the difference between new oil and 3000 mile oil. Still has the honey color. Start up rattle is there though but it has always been there.
  7. Hltoppr
    Hltoppr SILVER Star
    2,020
    Media:
    4
    3
    Aug 29, 2002
    Port of Indecision...otherwise Northern Arizona
    What's the P/N of the K&N, BMT?
    -H-
  8. BMT
    BMT
    325
    Apr 1, 2003
    I believe the K&N part number is #3002 but you can look it up in the K&N book.
  9. Wrench
    Wrench One Bashed Up 80
    4,492
    178
    Mar 27, 2003
    No it is 3614. This is the small one.
  10. CDN_Cruiser
    CDN_Cruiser
    1,047
    Mar 27, 2003
    What's going on here? I called my local dealer and they tell me that "the 90915-20004 filter has been replaced by the yzzb5" and they don't stock the 20004 and that there is no quality difference.
    C-Dan, is this correct? Semlin, where did you order from?
    Cheers, Hugh
  11. cruiserdan
    cruiserdan SupportingVendor Emeritus Supporting Vendor Moderator
    20,603
    2,981
    Mar 27, 2003
    Surrounded by Cruisers from all over the world
    Hugh,
    the 90915-20004 is still a valid number. The dealer in question may have done an in-house pnc (part number change) to reduce the numbers to deal with. As most people are cheap and don't want to spend the extra money, not all dealers will want to stock the 90915-20004. The minimum quantity they can order from Toyota is 10. If your local dealer is not stocking the filter for the above mentioned reason, you may offer to buy a box of 10 if he would get them for you. Oh, and since it's a "case" maybe he could sharpen his pencil for you. 8)
  12. semlin
    semlin rocker
    5,209
    Media:
    1
    324
    Mar 27, 2003
    north of 49
    Hugh, I got it from a local Toyota dealer, but they had only the YZZ filter showing on their system as well - could be a Canada thing. I gave them the part number and asked them to just order it. They were surprised but they obliged and it arrived three days later.
  13. MoJ
    MoJ Moderator
    3,309
    75
    Oct 24, 2003
    Wix oil filter part number
    This was the oldest filter thread I could find. Back in the day when 20004's flowed like tap water.
    Anyway,
    51515
    Is that the part number Wix users are using?
    Jason
  14. tarbe
    tarbe
    1,445
    6
    Aug 6, 2004
    Houston, Texas for now - Romance, MO soon!
  15. photogod
    photogod
    1,579
    4
    May 21, 2004
    MN physically, MI spiritually
    Wix and NAPA. Same filter.
  16. medtro
    medtro
    5,628
    455
    May 31, 2003
    51515 is the big filter. 51348 is the small one, as big as the 20004.
