Well, instead of continuing to hijack the antifreeze thread, here's one dedicated to the woodstove with oil drip. Pics here. Any questions or requests.......I'll try to answer them.
When I got my shop stove, the dude that made it had already welded in a threaded bung just for oil drip. I picked 3/8" flexible copper tube and used compression fittings, bushings, and couplers to make it all fit together. Use whatever sized you want, but remember that if it's cold, oil will take a while to get there in a smaller tube. I drilled a hole in the bucket and used nut-seal-bucket-seal-nut to make it leak proof. Any kind of valve will work, faucet type, 1/4 turn, etc, but you see what I used.
I dump another 5 gal bucket of used oil in when it gets low. No screen , but I would filter out pine needles and other coarse debris.
I have to clean the bung at the drip site once in a while, I just stab a screwdriver up from the inside while the stove is cool.
