OEM Carburetor rebuild kit include the secondary diaphragm?
Discussion in '60-Series Wagons' started by BigO77, Aug 17, 2010.
  1. BigO77
    BigO77
    59
    1
    Jan 24, 2009
    Savannah, GA
    Does the Toyota carburetor rebuild kit you get from the dealership include the secondary diaphragm? This is for an '85 FJ-60.
    From what I can tell from searching, a lot of the aftermarket kits include the secondary diaphragm, but it is the wrong one for the '85 2F carb. Is this true?
    I am going to rebuild the carb, and just want to make sure I have everything before I get started.
    Thanks.
  2. hank14
    hank14
    2,370
    33
    Nov 26, 2004
    Texas
    I ordered a carb rebuild kit from cruiserdan at American Toyota. It did not have the secondary diaphragm- had to purchase it separately.
    You might call Kurt at Cruiser Outfitters or Mark A. at Mark's Off Road for the rebuild kit and diaphragm.
  3. 2mbb
    2mbb
    4,611
    52
    Sep 1, 2003
    WC, CA
    OEM kits I've purchase do not have a diaphragm. I did purchase a Hygrade kit that did come with a diaphragm but it's apparently a diaphragm for an earlier carb. That kit is for a wide range of 2F carbs not just the FJ60 carb.
  4. Spike Strip
    Spike Strip My Piston is Air-Cooled SILVER Star
    10,501
    622
    Nov 22, 2005
    818
    See my sig line for Marksoffroad.net .... CALL after 1pm. Don't email. Mark has them.
    The correct diaphragm was avail from NAPA, but seems to be a little hard to find, now.
    NAPA part # CRB 24093
    Beck Arnley 167-0008
    Niehoff FS468
  5. cruiseroutfit
    cruiseroutfit Supporting Vendor Moderator
    5,391
    998
    Jan 9, 2003
    Utah
    We've both got them in stock :D
  6. Cliffs60
    Cliffs60
    32
    Media:
    2
    Dec 31, 2009
    SLO, California
    yeah they are hard to find but you can get the part number and take it to napa and you should be able to find it. I'm not sure where I found it but i was surfing some threads and someone kind enough poted it. thtas the easiest way to do it no shipping or anything and it's the right one.
  7. BigO77
    BigO77
    59
    1
    Jan 24, 2009
    Savannah, GA
    Thanks all. I will give Kurt a call and order them.
  8. FJ40Jim
    FJ40Jim The Cruiser Whisperer
    8,957
    679
    Sep 26, 2003
    Lancaster, Ohio, USA
    More PN's
    More PN's for reference.
    Secondary diaphragm :
    Niehoff FS468
    BorgWarner (now BWD) 641668A
    Toyota 21669-61100
    Floats:
    Hygrade FL31
    GP Sorensen 779-8003
    Walker 100-139 (sometimes not OE)
    Tomco 737 (sometimes not OE)
    Carburetor kit w/ straight stem sec. diaphragm :
    Hygrade 791B
    GP Sorensen/Carburetor 96-309B
  9. Godwin
    Godwin Resident Herpetologist SILVER Star
    3,543
    809
    Dec 4, 2004
    Alabama
    Assuming OEM is the best how do the others compare quality-wise?
  10. FJ40Jim
    8,957
    679
    Sep 26, 2003
    All the others listed above OEM, appear to be identical to each other. They are made in USA and of excellent quality. I suspect they all come out of a factory owned by Standard Motor Products.
  11. TobyB
    TobyB
    1,275
    29
    Jan 18, 2011
    Seattle
    napaonline, 16.99 !
    Thank you, Jim.
    t
