- Location
- United States
OEM brake hoses!
Background:
The front brake system has a total of 3 flexible lines, one in the center, and two on the sides. The center hose connects to the brake tube, which distributes fluids to the sides.
Front flexible hoses (1 needed per side). Part # 96920-32255.
The length is approximately 8 3/4" end to end, including the fittings. The rubber portion is approximately 5 3/4".
Several sets available. $66 for a set of 2.
Front center hose. Part #96940-32605 (superseded part #96940-30265). The length is approximately 10 1/4" end to end, including the fittings. The rubber portion is approximately 6 7/8".
Several available. $33 each.
Rear Center brake hose to the rear brake tubes. Part # 90947-02230. Measuring 17" long from end to end (rubber portion is 14"), this mission critical hose is situated between the drive shaft and the right side of the frame, directly facing the road elements below. Rarely found in the Toyota inventory system. Only 1 available. $47.
Shipping is $3 flat rate, regardless of how many hoses you get.
Please PM if interested.
Background:
