OBD II SCAN TOOL
Discussion in '80-Series Tech' started by Luago, Jul 11, 2003.
  1. Luago
    Luago
    4
    Jul 11, 2003
    8) I have a 97 80 and need advise for wich tool do you recommend based on your experience.
    Thanks
  2. Gumby
    Gumby Supamod Staff Member s-Moderator
    11,778
    308
    Dec 13, 2002
    Knee deep in hookers and gin
    Depends on how much money you have and how much you are going to use it.
    A bottom of the line code reader is about useless, but pretty cheap. I can't tell you how cheap, because I wouldn't take the time to find out.
    A real scan tool will cost about $2000 for an OTC genisys.
    I like the Snap On MT2500 better for about twice the price.
    Snap Ons new Modus is about $7000 with a five gas analyzer, an o scope and a nice large screen
    The Toyota service center one should be available because of OBDII laws, but I don't know where you can get one. I just did the Ford training this week and thiers was $30,000 and included limited factory support. It allows you to read all the data stream and drive all of the controls. You can honk the horn, turn on lights, anything that is module controlled. You can also reflash EEPROMs if you have that capability. C-Dan says 2K and up Cruisers. Very, very nice if you have a large volume Toy only shop and/ or lots of disposable income. :D
  3. Beowulf
    Beowulf
    12,534
    30
    Mar 27, 2003
    Somewhere in the foothills...
    Luago,
    There are a lot of OBD-II scanners in the market so you'll have to be specific on what your requirements are, including your price range. Do some research here http://www.obdii.com/ and post back your detailed requirements.
    For example, my requirements were for a simple device that would work on my 97 Cruiser and other friend and family vehicles. This means the device would need a "universal" type of interface and software. Low price (under $200) was a major requirement. My only technical requirements were that it had to read stored MIL codes and reset them. (They all do this!) I love Palm devices and wanted one that would work with a Palm and a laptop PC (WinPC.)  The Palm capability was a "nice-to-have" but not required.   Displaying standard OBD-II signals in real-time was another "nice-to-have" for me.
    What this leaves out in the above requirements is a lot!!
    For example:
    * Toyota specific diagnostics
    * Ability to capture, store, and recall stats from many vehicles.
    * Touch screen operation (like an auto shop might use)
    * General diagnostics with help on how to resolve problems by code.
    * Sophisticated user interface and software
    * ... and lots more features the pro units have ...
    I selected the OBD-II device from Harrison R&D. (http://www.ghg.net/dharrison/)  It met my requirements above but it is a minimalist solution.  There are much better units available and I did very little research before selecting their product.
    Bottom line is that it works, it's cheap, and it met the specified requirements.
    -B-
  4. Gumby
    11,778
    308
    Dec 13, 2002
    B-
    Will it read data stream? If so, it would be worth it. Codes are very misleading without data. For instance an intermittant miss could show up as a O2 out of range, a cat failure, a fuel trim problem, or a number of other codes. sometimes a little informations can be a dangerous thing.
    If all you want to do is pull codes and reset lights, it would be pretty neat to be able to use a PDA to do it, but, for me, not worth too much money.
  5. Beowulf
    Beowulf
    12,534
    30
    Mar 27, 2003
    Gumby,
    I think the answer is yes, but due to my limited knowledge of devices other than this one I'm not really sure.
    From their web site:
    Our Data Log function allows you to log four sensors simultaneously.  The data is recorded as fast as the vehicle will respond and the length of the data log is only limited by the amount of free space on your hard drive.  Data is time stamped and comma delimited for easy import into Excel™.
    Here are a couple of screen shots running on a PC:
    [​IMG]
    [​IMG]
    -B-
  6. Pin_Head
    Pin_Head
    13,743
    1,312
    Feb 6, 2002
    OC, CA
    I have had the Harrison OBD-II tool for 4 years and recently updated the software (free) so that I can continuously graph the data. You could always monitor an input in real time. Now it graphs and stores. it. It is a lot of bang for your $150- bucks, but you will need a laptop computer to work with it. It has saved me a bunch of money over the past few years.
  7. Gumby
    11,778
    308
    Dec 13, 2002
    If it reads data and graphs, it looks like something I'm really interested in. For >$200 I can give my students real experience with scan tools. there's no way I can afford more than one Snap on scanner.
    I'm sold. :D
  8. Beowulf
    Beowulf
    12,534
    30
    Mar 27, 2003
    Gumby,
    Don't be too put off by their web site. It's horrendous. The OBD-II device and the PC software are definitely not professional quality. It is obviously a hobby box and software developed by a one-man shop. I don't even think he is a professional programmer as the interface looks amatureish. However, it works and does what I needed it to do. The Palm version is a little more professional than the PC version but limited of course, by the limitations of a monochrome PDA screen.
    -B-
  9. Rich
    Rich
    1,805
    3
    Jun 16, 2003
    www.autotap.com - Haven't used it, but it looks quite a bit more polished.
  10. sleeoffroad
    sleeoffroad Supporting Vendor
    6,056
    531
    Mar 27, 2003
    We use the one from these people. http://www.obd2.com/
    The price has gone up, but the interface is pretty good. I used to have a cheaper one that work for personal stuff, but was not good enough in the shop.
    It does all we need it to do, except for being able to "talk back to the car" in that one can not operate valves etc etc like with a proper scantool. Also, I have the laptop version, and would love the PocketPC model, but they do not offer an add on. Essentially have to buy the whole thing again.
    Kind a frustrating.
  11. landandsea
    landandsea
    299
    May 31, 2003
    I've been using the AutoXray EZ Link scanner. www.autoxray.com. Cost $259
    Check out my post in the thread "back from mexico"
    eD
