On Board Air System Installed & Working
I'll try to make this short and sweet without leaving anything out (hopefully).
It started with a simple sketch:
Then I just started collecting parts.
YORK 210 Compressor - eBay
Compressor Bracket, Pulley, and Air Manifold - Slee
50' 3/8" Air Line & Fittings - McMaster-Carr
150 psi Pop-off (safety) Valve & Check Valve - McMaster-Carr
Pressure Gauge, Pressure Regulator w/ Gauge, & Air/Moisture Filter - Lowes
YORK 8-AN fitting - NAPA
Hi-Temp Leader Hose - Amazon
Adjustable Pressure Switch (Square 'D') - eBay
2.5 gal Air Tank - eBay
Quick Release Air Fittings - Sears
Rubber Air Fitting Covers - Kilby
Toyota Hazard Switch (for power) - eBay
Various Adapter Fittings - Industrial Liquidators (Kearny Mesa)
Misc. Hardware - Lowes
Then came the assembly:
The fresh air line and fittings were left over from an old VW I used to have when I was 18. It routes under the air filter and attached to a bulkhead fitting centered on the housing. The Square 'D' pressure switch is set to turn off @ 130 psi. It has about a 15 psi range from stop to start. When the system hits 115 psi, it turns the compressor back on.
90° Bulkhead fitting inside air filter:
[EDIT]
Air/moisture filter:
[/EDIT]
Because the Slee Manifold is tapped for ARB switches (British threads), I had to re-tap to accept 1/8 pipe threads for the 150 psi pop-off valve. The valve is behind the system pressure gauge.
Air lines to tank and rear quick connect:
I used the existing running board mounting holes and hardware to mount the lines.
2.5 gal Air Tank:
The air tank mount is the OEM spare tire carrier, flipped over, spaced down and trimmed to fit around the Slee hitch. You can see the spacers in the photo above (middle right). The pressure release for the tank is cable actuated, so I don't have to crawl under the truck to release pressure.
For the Quick Release air fittings, I went to Sears. Their fittings allow for one handed connections (you don't have to pull back on the collar to connect).
And finally, the power. I picked up a Tercel Hazard switch on eBay for 99¢, mapped out the pins and connected power. My wife made the "cute" button icon.
A few rigs (Bluetribal, KightOwl, and myself) took a trip to Anza-Borrego last weekend (note the mud in pictures) and had a chance to test the system. It worked flawlessly. We aired down and up at will.
BTW: I have a hand throttle, so when airing up, I locked the RPM's in around 1,000.
Enjoy.
[EDIT]
[/EDIT]
2.5 gal Air Tank:
Enjoy.
