So, why would you buy the Toyota one?
Because they are absolutely better quality than anything aftermarket.
I'm going with the Toyota parts. Now, should I replace my O2 sensors (318,000 miles and no codes) or should I try to get my money's worth out of them??
The million dollar question? Replace ($$$) or Clean your O2 sensor .
Replace the oxygen sensor only if it's bad. They do wear out and the FSM, Chilton's or Hayne's manual for your car should have directions on how to test it.
An OEM replacement sensor for some popular cars is about $240, and your car probably has two of them. If you replace it with a cheap sensor from a discount parts store, you may be throwing away a perfectly good high quality sensor which just needs to be cleaned.
Here's a quote from a Toyota mechanic with 32 years of experience, on another web site:
"You don't need to replace them, remove them and clean them. [If you read an O2 sensor malfunction code] The computer is saying the vehicle is running a little rich or lean. IT DOES NOT mean the sensor(s) are bad. Auto parts stores just want to sell you products. If I received a dollar every time a 02 sensor was replaced on a vehicle I'd have millions."
That said, there doesn't seem to be an "official" way to do it, or an entirely safe way. But since you ask, here are some ways people have done it:
1. Clean it with a throttle body aerosol cleaner which states that it's safe for oxygen sensors.
2. Heat it up with a torch and dip it in water. Use an air hose to clean the gunk out. Repeat.
3. Soak it in "Seafoam" (the engine cleaner, not salt water) overnight.
4. Soak it in gasoline overnight. Shake the dissolved gunk out.
It's one of those things, like nobody's going to tell you how to clean your bathroom mirror with ammonia at $0.99 a gallon, but lots of people are happy to sell you ammonia with blue die in it at $4.50 a pint.
Sam: Stewart: It's possible the PO replaced my O2 sensors before I got the truck but the old service records don't show it and they are Toyota sensors. Only thing I've noticed is the loss of maybe 1 mpg in the last few thousand miles but then the exhaust doesn't smell funky, no soot blowing out the tailpipe. I've only got one O2 sensor code after recently using Honda intake/top end cleaner, cleared it, hasn't come back. I'll see about checking live data from the sensors. Is there an affordable scan tool that will show live data?
Edit: it would be interesting to see some live data before and after cleaning.
I just ordered a set of Denso O2 sensors from here:
http://www.oxygensensors.com/catalog.php?&pkey=1276703
They look identical in every respect to the factory parts and are plug and play connectors.
Part 234-4157
Part 234-4153
$156.32 total. I'm happy
They arrived packaged in perfect condition in two days.
Mine were replaced under warranty at 40K. Stealership making bucks no doubt.
Looking forward to install of new parts at 155K.
I must have missed it, but what sensors for a 94? Thanks!
The 94 takes NTK sensors. I was told Denso's by several people on this forum, just ordered a set from Lowe Toyota ( think I spoke with a guy named Ernie, awesome customer service btw ) and the package I got has x2 brand new OEM sensors marked NTK Toyota.
