No power from engine to driveshaft
Discussion in '40- & 55-Series Tech' started by 78mustard40, May 6, 2003.
  1. 78mustard40
    78mustard40
    17
    Jan 31, 2003
    New centerforce clutch and stock trans/xfer with sbc. This drivetrain was assembled and put aside more than 4 years ago and was put in the vehicle a couple months ago. Cannot get clutch pressure to flywheel. Anything to do with sitting for that long? Scratching my head here and seeing if this rings a bell with any of you before I pull it apart.
  2. woody
    woody Internet Fireman Staff Member
    10,329
    Media:
    303
    1,084
    Jan 15, 2002
    Toquerville UT
    install the disc backwards?
    Do you have the inspection cover? Should be able to see inside and visually see if things are touching or not, and have an assistant run the pedal and check for disengagement or something wrong.
  3. FJAfrica
    FJAfrica
    205
    1
    Dec 8, 2002
    Cape Town, South Africa
    :slap: Happy stripping....Definately sounds like that clutch ain't put in right
  4. 73fj
    73fj Tho at sumbitch in ayer!
    1,058
    Media:
    36
    72
    Mar 16, 2003
    Grande Prairie, Alberta, Canada
    :dunno:did you get the right bearing?i had the same problem and got a longer bearing out of a 68? works fine now.
  5. 78mustard40
    78mustard40
    17
    Jan 31, 2003
    Yeah...the disc was in backwards. I was too tired after that job to laugh because even the sticker on the disc that says "flywheel side" was still on it :stupid: !! Still gotta wrestle the trans/xfer back in today. What have you guys used to hold and lift this assembly working from the garage floor. Was wondering if one of those transmission adapters that go into the post on a standard floor jack might help.
  6. 3_puppies
    3_puppies SILVER Star
    8,317
    218
    Dec 2, 2002
    Helena MT
    helped a friend one time, he rolled down his windows and stuck a wood 4x4 across and used a comealong. worked pretty slick.
  7. woody
    10,329
    Media:
    303
    1,084
    Jan 15, 2002
    Toquerville UT
    wood across the door frames
    wood across the full cage spreaders
    bench press -- my SM465 is WAY too heavy for this, but I've done the stock 4-speed/t-case combo this way many many times.....tho, maybe this explains my rotator cuff problems...hehehehe (feet towards the engine, press into place with yer arms and get initial alignment, then slide back and with yer hands on the t-case and yer feet on the bellhousing, jiggle into place....cuss words optional...)
  8. Chef
    Chef
    1,972
    6
    Jan 24, 2003
    Columbia, MO
    I like to use an engine hoist thru the tranny tunnel hole to pick up the combo and sling it into place...Motorcycle tie downs around the pair make end to end height adjustments easy...
  9. 78mustard40
    78mustard40
    17
    Jan 31, 2003
    Everything is together. I ended up using the transmission adapter welded to a spare floor jack. Put the rear tires on ramps, about 12" high, and with new 35" tires got a lot of room to move around. Worked pretty slick.
