No more dino juice
Discussion in '80-Series Tech' started by Curran, Apr 17, 2003.
  1. Curran
    Curran SILVER Star
    824
    5
    Mar 27, 2003
    Frederick, MD
    I'm making the switch to synthetics (transfer and engine) today in search of better gas mileage. :ugh: I'm a bit nervous due to rumors about dissenting gaskets and such. 85,000 on the ticker...
    Wish me luck.
    CJ
  2. yomama
    yomama
    291
    Mar 27, 2003
    Don't expect miracles. You might gain 1 mpg. It is jsut better for your cruiser.
    Yomama
  3. davidfj406080
    davidfj406080
    193
    1
    Apr 6, 2003
    Albuquerque, NM
    AMSOIL now has seal swellers, but I haven't upgraded to it just yet. Yes I'm biased as I've been a 'dealer' off and on for years but never did much except subsidize my own habit. I think the tranny will be the first to switch over-
  4. Jacknasty
    Jacknasty
    45
    Apr 15, 2003
    I tried the Amsoil in my 4runner and it didn't last long at all. I went almost 5,000 miles on it and when I changed it, it looked horrible. I have heard stories of people changing it after 8K miles and it looking like it just went in. Mine was nasty looking and I didn't drive my runner hard at all. I might stick with the Quaker State synthetic and change it at regular intervals.
    I wish the Amsoil would have held up, especially since I paid around 8 dollars a quart for it. :eek:
  5. firetruck41
    firetruck41
    5,732
    10
    Mar 27, 2003
    Camas, WA USA
    Jacknasty, the amsoil may have just got everything in suspension that has been in your motor for a long time, might try using it a second time to see if it's any better. Just a thought.
    Curran, I just switched to mobil 1 full synthetic 10w 30 last night, I've got 179k miles. I don't expect any problems, I've switched all my cars to synthetic engine oil for the last six years, a 93 BMW 525 w/55k, a 92 Honda Accord w/140k, a 90 Mitsu Montero w/~100k, 96 Toyota T100 w/50k. Never had any leaks on them after the switch, hopefully no different with the LC.
    Alittle increase in mpg would be nice but, mostly I like that it doesn't break down as badly as dino, and I won't feel bad changing it at 6000-7500 (mall cruisin) miles.
  6. Jacknasty
    Jacknasty
    45
    Apr 15, 2003
    You might be right, but it was too expensive to keep experimenting. I would rather use Mobil 1. My dad has always used Mobil 1 in his Corvettes and if it is good enough for the Corvettes and Porsches, it's good enough for the Landcruiser :G
  7. tiorio
    tiorio
    378
    Apr 11, 2003
    Another oil thread, OH NO!
    Anyway, I run synthetic in the Porsche turbo, as the turbocharger runs hot and really needs all the help it can get (the motor being air cooled and all). I change every 3-5k.
    I run dino in the LC. The sump is huge (comparatively) and I change every 3-5k so the major benefit of syth, longer life in the engine between changes, doesn't really apply. Esp. for the cost/benefit with 8 quarts every 3-5k!
    Just my .02, worth less on eBay...
  8. landtoy80
    landtoy80
    5,668
    241
    Mar 13, 2003
    North Front Range, CO
    I swiched to Mobil 1 at 210k mi. I have several leaks to take care of that were there before. I tighten the pan and stopped that leak. I used the Mobil 1 10w30. I changed the filter at 3000 mi and after tightening the pan there is no oil consumption.
    kurt
  9. moralien
    moralien
    381
    Apr 17, 2003
    On the catwalk.
    If you were running a quality synthetic (red line, amsoil, royal purple) than you should be able to get more like 8k out of it. Pay attention to the fluid level, and change your filter out at 4k.
    Just my.02
  10. landtoy80
    landtoy80
    5,668
    241
    Mar 13, 2003
    I don't know how to make synthetic oil but I have herd that crude oil is not from Dino. It is believed that oil is naturaly occuring deep in the Earth. Oil can be made with water and minerals and high presure equal to what is found deep in the earth. I have a hard time with that many dino's died in one place at one time and then all the energy form them drained deep into the earth. This had to happen in all the placed that oil is found. Just a thought.
    kurt
  11. davidfj406080
    davidfj406080
    193
    1
    Apr 6, 2003
    Albuquerque, NM
  12. davidfj406080
    davidfj406080
    193
    1
    Apr 6, 2003
    Albuquerque, NM
    Hey Jacknasty, I have heard of things like that happening- I'd maybe give a synthetic another try- You can really get some garbage build up in an engine over time- are you running a K&N? They let a lot of crap pass through. I have one in my Tundra but I have several associates who have sworn off them as we live in a very dusty environment and many believe that they let a lot of parrticles pass through. Synthetics last longer- they don't break down as fast as dinosaur oil over time/ temps..... I have no economic interest in this discussion as I said, I only subsidize my habits
    My .02, sure to cause a ****storm....oil David O'N :beer:iell
  13. MTNRAT
    MTNRAT
    1,181
    18
    Mar 27, 2003
    Fernie B.C.
    landtoy, think plants man, PLANTS. :slap:
    Regards, Sean
  14. Guest
    Guest Guest
    So is everybody thats using synthetic oil running the regular recommended weight(as in 5w30)or something different?and why?
    just some saturdaynite contemplating.......
    doug(who still cant come to terms with 40.00+ for 8 quarts of oil)(and still want to be anal and change it at 3000 miles)
  15. SpaceGhost
    SpaceGhost
    467
    1
    Feb 1, 2002
    Indianapolis, Indiana
    If you are gonna change it at 3000 miles, any readily available oil will do just fine. Even the cheapest stuff.
    I have 60k on my powerstroke and since switching to amsoil at 5k I haven't done an oil change. Bypass filters and extended drain intervals will get me to 100k before I uncork the oil pan. With synthetics in your Cruiser (and my 2000 FZJ100) you can change to it, then at 5k replace the filter and top it off, again at 10k, then at 15 change the oil and filter.
    Your tranny will be the happiest with the changeover if done before you rack up lots of miles and have already worn or damaged it. The temp at which synthetics crap is lots higher than petroleum based lubes, this alone will make the tranny happy.
    Same with power steering. A good cooler and synthetics will make a big difference in a locked up rig that is wheeled at a slow but strenuous pace.
    Amsoil specifically will mix with all petro based fluids of similar specs and intended usage. Yes I am a dealer, but only for my personal useage, but more importantly I am a believer!
    Needless to say I run Amsoil products everywhere in all my vehicles and fleet (at work). My sm420 never shifted better till I filled it with Synthetic gear lube. Sorry if this sounds like a commercial, don't contact me to buy it, just adding my experience with the product. BTW, it's only $80 a year to be a dealer and save some serious $$$ over retail.
  16. firetruck41
    firetruck41
    5,732
    10
    Mar 27, 2003
    Camas, WA USA
    96cruiser- I use 10w30 mobil one synthetic, same viscosity that is recommended in the owners manual fo dino oil. I haven't heard any good arguments to convince me to switch to another viscosity yet. I've usually changed oil at 7500 on vehicles when using synth even though that is the recommended interval (normal driving conditions) for conventional oil for most cars, so I'm sure it could go much longer without worry. If you have a Walmart near you, you have a cheap source for mobil one oil, 5 qt jugs for $18.88. 3 jugs will get you 2 oil changes, less than $30 in oil per change.
    Walmart does not have synth tranny fluid or gear oil, and I haven't switched the cruiser over to those yet, I just found out when getting the oil filter at the dealer last week, that it had a tranny, trans and diff fluid service only a year ago, so I won't worry about it for a little while.
  17. Beowulf
    Beowulf
    12,534
    30
    Mar 27, 2003
    Somewhere in the foothills...
    Doug,
    I tend to believe Mike's (SG) assessment though I don't practice it.
    I got my '97 about 20 months ago. It had documented oil and filter changes by the PO at 3k intervals using Castrol full synthetic.
    I have continued the full synthetic (Mobil-1 5w30 cold weather and 10w30 warm weather) but have extended the drain intervals to 5k miles (Oil and filter.)
    I simply don't have the courage to move to 15k intervals with 5k filter changes. It makes sense and I want to believe it but I just can't bring myself to try it.
    I have heard of and know of a high percentage of 90-100k 1FZ-FE's with rear main seal leaks. My gut feel is these are vehicles with poor oil change history. Mine doesn't leak a drop of ANY fluid (knock on wood!)
    Buy your Mobil-1 at Wally World like Firetruck said. The price isn't not too bad considering the peace of mind and the cost of a rebuild on these engines!
    -B-
  18. cruiserdan
    cruiserdan SupportingVendor Emeritus Supporting Vendor Moderator
    20,603
    2,981
    Mar 27, 2003
    Surrounded by Cruisers from all over the world
    -B-
    A footnote:
    Often the "rear main seal" oil leak is in fact the seal retainer to upper oil pan rail seeping. If one does this job it is prudent to pull and reseal the retainer as well as the seal as the retainer is often the origin of the leak............... :beer:
    &nbsp:Dan
  19. landtoy80
    landtoy80
    5,668
    241
    Mar 13, 2003
    ]landtoy, think plants man, PLANTS. :slap:
    Regards, Sean [/quote]
    Plants = Coal
    Dino = oil if you can believe that
    kurt
  20. landtoy80
    landtoy80
    5,668
    241
    Mar 13, 2003
    Dito, I wish is would of known of the retainer so I wouldn't of have to drop the trany twice. :(
    kurt
