fyton2v
Let's pretend that you drained the oil from from your transfer case, with good intentions, and then stripped the fill bolt beyond all hope of a simple removal. How would you refill the transfer case with oil?
Remove the breather and fill it though their.Let's pretend that you drained the oil from from your transfer case, with good intentions, and then stripped the fill bolt beyond all hope of a simple removal. How would you refill the transfer case with oil?
Don't drive it with out oil in the case- very bad for the gears and bearings. Use a oil pump hose to put the oil in from under the truck. I found one at the blue box store that screws onto the top of the gallon oil bottle... works great for filling the trans as well.
HTH,
Will
Try heat and hammer a cold chisel to dig in and spin it off.
I have a torch, but am somewhat hesitant about using fire in that area. I'll give it a try and keep some marshmallows handy.
